What u guys think about this combo.
why go SOHC when you can Go DOHC
Its only a matter of a couple hundred dollars or so.
If you need help making up your mind GIVE me ( Rob or Nick )
a call at No Limit Motorsports
631-363-8659
631-363-8659
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoLimitMotorsports »</TD></TR><TR><TD CLASS="quote">why go SOHC when you can Go DOHC
631-363-8659</TD></TR></TABLE>
Was...was that a plug?
if yo uuse a vtec block and a a6 head. (assuming you are using the vtec pistons) you will have a CR that is lower than you probly want. if you do this get teg pistons so at least there will be a little CR.
most people do the opposite of what you are doing. A6 block, vtec head.
SOHC are good, cheap, & plentiful (not to mention if smog is a problem)
enjoy.
enjoy.
Radioactive
43
Apr 28, 2004 09:11 PM
