Turbo from a Volvo
sure, but it will need to work much harder to get up to speed.
like bigger turbo will push out more air at lower rpm while small turbo have to work at higher psi to push out the same amount of pressure.
you prolly be better off with a t3t04, they are not very expensive.
maybe use the t3 if it's in bling bling perfect condition
I would be shocked if a turbo that old would actually work. Just get a T25, or T3/T4. The T25 would be cheaper. You can probably find one in a junkyard for very cheap. Got to take it from a 1G, or 2G Turbo DSM. And if you are concerned with power gains, the T3/T4 will give you more power than the T25.
http://board.hondasociety.com/...mitsu This might help. TeamElusive has a custom turbo setup in his JDM F22B. Not too familiar with the similarities between the F22A, and F22B.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 »</TD></TR><TR><TD CLASS="quote">I would be shocked if a turbo that old would actually work. Just get a T25, or T3/T4. The T25 would be cheaper. You can probably find one in a junkyard for very cheap. Got to take it from a 1G, or 2G Turbo DSM..</TD></TR></TABLE>
I wouldn't go for a T25, because they are too small to work very efficiently with our engine. The 1G turbo is the 14b (or g, I can't remember). That one would be better, but is still really small for our engine. A T3/T4 would be your best bet.
kPRO dz
10
Mar 1, 2010 05:14 AM
street_ride14
Jun 21, 2008 09:27 PM
