Anyone running the Addco 88-91 Swaybar?
Old Jun 27, 2003 | 06:16 AM
Todd00's Avatar
I said I don't want a title!
Default Anyone running the Addco 88-91 Swaybar?
If so, have a few questions for ya:
The endlinks--did you use the supplied collars with them or not? The instructions are so vague. I did not and I have a lot of play in the endlinks. I'm thinking I will need to shim them up. I'm also thinking the swaybar was desinged for cars with a oem rideheight. Since I am a lot lower, the endlinks are not sitting as they should.
Otherwise, the bar seems to fit well after you redrill the bracket, enlarge the slots and use different bolts to hold the brackets to the control arms
Edit: I know someone on here has one because we were chatting via IM. If you see this, IM me back. I forgot your username!
Old Jun 27, 2003 | 07:06 AM
jc836's Avatar
Default Re: Anyone running the Addco 88-91 Swaybar? (Todd00)
ADDCO rear Sway Bar #456 on our race '89 CRX Si was installed as supplied with all parts used. That is the correct way to do it. The install on the Lower CA's uses the stock location. You should only use the supplied hardware and brackets along with the stock bolts if needed. BTW: Our car is lowered to SCCA's 5" spec and no clearance problems at all.
im_inn0c3nt
Jul 16, 2010 09:52 AM
rankin_wanavtec
Feb 20, 2010 07:26 AM
JapJunkie
Feb 8, 2005 12:40 PM
GraphiteAccord
Feb 10, 2004 07:44 PM
isledude
Aug 10, 2002 12:53 PM
