Pistons.
My question is what pistons should I run in the B20 I'm building also I'm trying to decide between Crower or Pauter rods?? help me please... As of now I'm running Jun3 cams, retainers, valve springs and Toda cam gears. Also is it safe to run and 12:5 compresion on 93 pump gas, daily driven.. I bet it would help if I said what type of head I have well its a 00 B16 head
Modified by Ebp00Si at 11:36 AM 6/27/2003
. Modified by Ebp00Si at 11:36 AM 6/27/2003
Do you plan on resleeving? If not 84mm Arias 12:1's. If so you can get GE or RS sleeved to 84 or 84.5mm. Arias makes 12:1's for both of these sizes in a B20 block using a B16 head. Or you could run their 85mm 13.8:1's.
Pauter and Crower and both excellent rods. I believe the crowers are a lighter rod found more so in all motor apps. Pauter is very popular with the boosted guys and a beefy rod.
Chugger
Jan 11, 2006 04:39 PM
