help please!!!!! help!!!! help!!!! all type R owners or gsr owners?????
Old Jun 26, 2003 | 11:51 PM
97jrscgsr's Avatar
Default help please!!!!! help!!!! help!!!! all type R owners or gsr owners?????
i have a 98 ITR and the p73 ecu got stolen i just want to know would a 98 integra gsr P72 ecu work? please let me know asap. thanks
Old Jun 27, 2003 | 08:46 AM
canuck-mx6's Avatar
Default Re: help please!!!!! help!!!! help!!!! all type R owners or gsr owners????? (97jrscgsr)
It would run the car, but the timing and fuel curves are all off. You need a P73
Old Jun 27, 2003 | 09:05 AM
nEoMuGen's Avatar
Default Re: help please!!!!! help!!!! help!!!! all type R owners or gsr owners????? (canuck-mx6)
VTEC at 4400 y0!
Old Jun 27, 2003 | 09:10 AM
RTW DC2R's Avatar
Default Re: help please!!!!! help!!!! help!!!! all type R owners or gsr owners????? (nEoMuGen)
wont there be some kinda conflicts with the ECU/distributor/key and you wont be able to start the car?
Old Jun 27, 2003 | 09:19 AM
canuck-mx6's Avatar
Default Re: help please!!!!! help!!!! help!!!! all type R owners or gsr owners????? (RTW DC2)
He has a 98, not ignition lock on that ECU
Old Jun 27, 2003 | 09:21 AM
RTW DC2R's Avatar
Thanks for the clarification.
Spoond TEG's Avatar
Get a immobilizer bypass unit from your local alarm dealer (Used when you have remote start) this will solve your problem. Then get a Clifford alarm system with wireless dual immobilizers and you solve your problem. Or Can't you just get a KEY programmed to the New ECU?
Old Jun 27, 2003 | 09:25 AM
Pacman
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97jrscgsr &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 ITR and the p73 ecu got stolen i just want to know would a 98 integra gsr P72 ecu work? please let me know asap. thanks</TD></TR></TABLE>
You are going to be fine...nothing is going to happend to the motor. The only thing is that you can't rave the motor pass 8000rpm that is going to be your redline.. Canuck-mx6 his is right for timing and fuel curevs but not that much because ob2 ECUS CONTROL ALL THE FUEL AND TIMING FOR SMOG REGULATION TO THE WAY SHOULD BE.
zhen_fai
Oct 13, 2008 09:15 PM
Blazeone
Jul 12, 2004 10:27 AM
bgod
Jul 27, 2003 07:51 PM
