Rebuilding motor, Q's on assembling
Old Jun 26, 2003 | 09:39 PM
AzG35's Avatar
Default Rebuilding motor, Q's on assembling
Well, after some costly mistakes at the machine shop, I had to purchase some 81.5 JE 11.5:1 pistons for my "poor man's type-r." The final CR should be close to 12:1 after decking and milling.
Hopefully I will get my pistons tomorrow and start the assembling. I would like to know if I should sand down the sharp edges of the pistons before putting them in?
Also, what do most guys run for ring gaps for the JE pistons? I have seen from doing searches that they should be = bore * .0045" to .0060" = .014 to .019. This is going to be an NA car, but it may see some N2O at some point.
Since the pistons have low silicon content, I know they will expand. That allows for greater piston to wall clearance as well. I have heard .003"-.004", what do you guys recommend? Thanks for any input.
Old Jun 27, 2003 | 12:56 PM
AzG35's Avatar
Default Re: Rebuilding motor, Q's on assembling (AzSi22)
bump
Old Jun 27, 2003 | 05:11 PM
Fkned2003's Avatar
usualy .004 per in. of bore
Old Jun 27, 2003 | 06:19 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (Fkned2003)
Fnkned, where is your shop located at? I'm guessing from the title that you build and prep racing heads. I never heard of Collingdales, so what is that near.
Old Jun 27, 2003 | 08:21 PM
Fkned2003's Avatar
about 5 mins. south of phila right off of I95. will be glad to help u .
Old Jun 28, 2003 | 02:07 AM
SIRX's Avatar
do not sand down anything on your pistons
the.hamburglar
Mar 6, 2007 10:03 AM
prostreetonline
Jul 20, 2004 11:21 AM
Rick Solis
Apr 16, 2004 11:53 PM
AzG35
Jun 26, 2003 09:31 PM
Watkinsm3
Apr 9, 2003 09:57 AM
