Rebuilding motor, Q's on assembling
Old Jun 26, 2003 | 09:01 PM
AzG35's Avatar
Default Rebuilding motor, Q's on assembling
Well, after some costly mistakes at the machine shop, I had to purchase some 81.5 JE 11.5:1 pistons for my "poor man's type-r." The final CR should be close to 12:1 after decking and milling.
Hopefully I will get my pistons tomorrow and start the assembling. I would like to know if I should sand down the sharp edges of the pistons before putting them in?
Also, what do most guys run for ring gaps for the JE pistons? I have seen from doing searches that they should be = bore * .0045" to .0060" = .014 to .019. This is going to be an NA car, but it may see some N2O at some point.
Since the pistons have low silicon content, I know they will expand. That allows for greater piston to wall clearance as well. I have heard .003"-.004", what do you guys recommend? Thanks for any input.
Old Jun 26, 2003 | 09:31 PM
Tweakmeister's Avatar
Default Re: Rebuilding motor, Q's on assembling (AzSi22)
ask this in the all motor forum
gsr95
Feb 6, 2008 12:40 PM
91accordexr33
Jul 1, 2007 10:31 AM
RACERDAN
May 2, 2004 05:27 PM
AzG35
Jun 28, 2003 02:07 AM
