Best Oil
I've got a 97 gsr w/ 75k on it. I run it pretty hard. The weather here is hot now. (65-100) What's the best oil to use? I've heard that once you run synthetic you can't go back so I was thinking of using a blend.
there's been some great discussions on this in the past (search).
that being said, I like Castrol GTX 5w30 on the dino side, and Mobil 1 5w40 (or 10) on the Syn side for cheaper, readily available oils.
you can switch back and forth, but try for consistency...it takes a few chances to fully flush out old oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdd »</TD></TR><TR><TD CLASS="quote">How about for turbo applications....any different?</TD></TR></TABLE>
heard that 5w is not thick enough for the turbo...
really? i thought the first one was...learn something new everyday
haha i got confused with viscocity..
i always use castrol 10w30. them syn stuff is too rich for my blood. i wished i could afford mobil 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdd »</TD></TR><TR><TD CLASS="quote">i always thougth the second number was how thick the oil was....</TD></TR></TABLE>
im pretty sure the first number is thickness...but yeah summer/spring 10w30, and fall/winter 5w30
i use mobile 1 syn.
i use mobile 1 syn.
I think it's like this:
1st number is viscosity properties when the oil is cold (it acts like a 10 weight oil)
2nd number is viscosity properties when the oil is hot (it acts like a 30 weight oil)
Basically a 10w-30 allows the oil to remain fairly thin when the temps are cold, and still remain stable when the temp rises.
I use castrol GTX 10w30 year round.
140k miles on the odo.
I would only use 5w30 if I lived in below freezing temps. we get maybe one of those a year in houston. so it isn't worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian_TII »</TD></TR><TR><TD CLASS="quote">I think it's like this:
Basically a 10w-30 allows the oil to remain fairly thin when the temps are cold, and still remain stable when the temp rises.</TD></TR></TABLE>
exactly
exactly
honda oil LOL
.. i use 5w30 full sythetic castrol.. its done me good for a good period of time now... no trouble so ill stick with it...where is the link for the oil compareson? i looked for it didnt find it...
I use 10w-30 Vavoline Maxlife, for my 94gsr with 120k miles.
I used to use 10w30 Castrol GTX or Pennzoil.
But "the best" oil at a "affordable" range has to be Mobil 1. I heard Amsoil was really good but no thanks for me at $8+ a qt.
i use honda oil when i take the car to the dealership for a change, if i do it myself...its mobil oil. mobil produces the base oil for honda and then honda adds its own additive.
