What engine is this??? DOHC non vtec???
Old Jun 26, 2003 | 08:03 PM
jetpilot's Avatar
Default What engine is this??? DOHC non vtec??? updated
can someone plz tell me what engine is this
its on a four door eg civic, its not an LS motor, its 1.6 and comes stock in four door EG civic Si´s in my country, i dont know what engine it is and its not aftermarket and its not vtec
heres another pic in a 93 del sol
I dont think its a ZC cause they are on four doors and they arent vtec (i think), they are stock engines on these cars
here are more pics
performance wise, how are these engines? How much power can be extracted from them? Is it better than a Z6? Thanks
Modified by jetpilot at 5:14 PM 6/27/2003
Old Jun 26, 2003 | 08:05 PM
91hatchcivic's Avatar
Default Re: What engine is this??? DOHC non vtec??? (jetpilot)
its the LS motor, b18b
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
LS engine 1.8 liter non vtec...b18b
Old Jun 26, 2003 | 08:18 PM
bryan305's Avatar
Default Re: What engine is this??? DOHC non vtec??? (ciRcuit_ _ _)
You sure? Kinda looks like a ZC valve cover to me
Old Jun 26, 2003 | 08:20 PM
fastwanabe's Avatar
Default Re: What engine is this??? DOHC non vtec??? (bryan305)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">You sure? Kinda looks like a ZC valve cover to me </TD></TR></TABLE>the timing belt cover looks ZC or maybe an older teg motor.
Old Jun 26, 2003 | 08:26 PM
eg crunkmonster's Avatar
Default Re: What engine is this??? DOHC non vtec??? (fastwanabe)
i think they are ZCs
Old Jun 26, 2003 | 08:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: What engine is this??? DOHC non vtec??? (eg cookiemonster)
looks like the vc off of my 89 teg.
Old Jun 26, 2003 | 08:31 PM
[Caster]'s Avatar
D16A8 - ZC
I have the same engine in my EG sedan and here in Australia they call them Civic Si as well, was only sold for a short time (1992 - 1994) as the top civic sedan model before it was replaced with the SOHC VTEC engine which they then badged as Civic VTi.
Old Jun 27, 2003 | 07:23 PM
jetpilot's Avatar
Default Re: What engine is this??? DOHC non vtec??? updated (jetpilot)
I added more pics
Is this a good engine for modding (I have a Z6) Will it give me more power if i go either NA or turbo, i currently have nothing on the Z6 and these engines are a dime a dozen in my country
thanks!!!
Old Jun 27, 2003 | 07:28 PM
liam821's Avatar
25 Year Member
Thats a ZC motor. There should be a "stamp" on the motor on the left front side where the tranny mounts which says "ZC" on it.
1.6L (1590 cc) DOHC non-VTEC
Horsepower - 130-137 hp @ 6800 rpm
Torque - 108ft-lbs @ 5700 rpm
Redline - 7500 rpm
Idle - 750rpm
Bore - 75.0
Stroke - 90.0
Compression Ratio - 9.5:1
Injection - Multi-Point PGM-FI
liam
Old Jun 27, 2003 | 07:31 PM
simplegreenmachine's Avatar
Default Re: What engine is this??? DOHC non vtec??? (91hatchcivic)
it looks like and older LS but not sure
Old Jun 27, 2003 | 07:38 PM
jetpilot's Avatar
Default Re: What engine is this??? DOHC non vtec??? (MonKey Magic SOHC)
Isnt the ZC a Vtec engine? I was under the impression it was. I have read its a D16A8 wich is a Zc sans Vtec.
If it is so a A8 how much power does it have? Is it good for Na or turbo (wich of both) thanks
Old Jun 27, 2003 | 07:42 PM
IM ALL BOB's Avatar
Default Re: What engine is this??? DOHC non vtec??? updated (liam821)
yup its a ZC MOTOR.. as honda did issue some eg models with the dohc 1.6 non vtec as well as the sohc vtec ZC motor..
PIC COURTESY OF KATMAN he does state that possibly only 2 yrs of the eg 92ish models came with a hydro ZC motor
Modified by IM ALL BOB at 9:44 PM 6/27/2003
Old Jun 27, 2003 | 08:19 PM
KevronsEG's Avatar
Default Re: What engine is this??? DOHC non vtec??? updated (IM ALL BOB)
100% ZC
Old Jun 27, 2003 | 08:42 PM
Shawn C's Avatar
In The Garage
thats a zc, but aren't there 3 different zc motors? a 1.6 sohc non-vtec, a 1.6 sohc vtec, and the ever-so-popular 1.6 dohc non-vtec? just wondering.......
Old Jun 27, 2003 | 09:45 PM
Acme2eg6's Avatar
Default Re: (22lbGS-R)
to all those people who thought it was ls motor. Remember honda puts motors according to the weight of vehicles. Such as b18a b18c1 in integras, h22a f22a in prelude and accords. ever notice the lightest car has the least ex. 88-91 hf @ 63 hp. just a thought
Old Jun 27, 2003 | 11:39 PM
ISELLRIGHTHANDDRIV
Guest
Posts: n/a
Default Re: (racemode)
it's a gray plug zc special addition motor out of an eg!!!
Old Jun 28, 2003 | 01:24 AM
Status Sean's Avatar
yea looks like a ZC motor to me
Old Jun 28, 2003 | 02:31 AM
TRAN's Avatar
Default Re: What engine is this??? DOHC non vtec??? updated (rw92civic)
yep ZC
Old Jun 28, 2003 | 02:41 AM
blacksheep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatchcivic &raquo;</TD></TR><TR><TD CLASS="quote">its the LS motor, b18b</TD></TR></TABLE>
no it's not! that's a ZC.. you can tell it's not an LS by the plastic cam gear cover on the valve cover
Old Jun 28, 2003 | 06:29 AM
mycvc8u2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot &raquo;</TD></TR><TR><TD CLASS="quote">Isnt the ZC a Vtec engine? I was under the impression it was. I have read its a D16A8 wich is a Zc sans Vtec.
If it is so a A8 how much power does it have? Is it good for Na or turbo (wich of both) thanks</TD></TR></TABLE>
looks like a zc motor and no.. the only zc i know of that is vtec is a single cam. i have never seen or heard of a dohc vtec that was a zc. just my .02
Old Jun 28, 2003 | 06:52 AM
viprcr1's Avatar
Default Re: What engine is this??? DOHC non vtec??? (mycvc8u2)
If you wanna know more about the ZC go to http://www.homemadeturbo.com this guy here has a fully built ZC turbo drag car
Old Jun 28, 2003 | 07:22 AM
Damon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycvc8u2 &raquo;</TD></TR><TR><TD CLASS="quote">
looks like a zc motor and no.. the only zc i know of that is vtec is a single cam. i have never seen or heard of a dohc vtec that was a zc. just my .02 </TD></TR></TABLE>
you are wrong Sir. I just spent last night ripping a ZC DOHC out of a friends CRX...(to be replaced by B17A)...They do make them, the pre-DA model tegs had them.
Old Jun 28, 2003 | 07:24 AM
Damon's Avatar
Default Re: What engine is this??? DOHC non vtec??? (Damon)
oh, and for those that arent aware, the ZC was Honda's worst idea ever. A single cam bottom end, with a DOHC head jerry-rigged on it.
The ZC is a very popular swap for people with Si CRX's...they can go from single cam to dual cam, usually picking up the block for around $300-400, and all the single cam componates move over (Tranny, axles, etc.)
Old Jun 28, 2003 | 07:31 AM
eg_nezay's Avatar
Yup, looks like a ZC.
To be 100% sure, look at the stamp on the block.
