ITR LSD in GSR tranny?
Old Jun 26, 2003 | 07:53 PM
Dan GSR's Avatar
Default ITR LSD in GSR tranny?
Is the ITR LSD a direct drop in for the 94 GSR tranny?
What other parts do I need?
Old Jun 26, 2003 | 08:50 PM
MaxSterling's Avatar
Default Re: ITR LSD in GSR tranny? (Dan GSR)
yes
Old Jun 26, 2003 | 10:31 PM
IN VTEC's Avatar
I'm not sure how essential it is to check the preload when you replace the diff assy (ask ***** or rodney), but it's recommended that you check/adjust the preload when you replace the diff assy.
If the preload is beyond spec, then you need to adjust the differential shim thicknesses. Make sure the dealership is open or that you can have down time with the car to get the appropriate sized shims. Or, maybe rodney has some laying around.
You might also consider replacing the diff bearings since you're gonna have to mess with the preload anyways.
Hondabond to reseal the casing.
3qts Honda MTF.
Old Jun 26, 2003 | 11:40 PM
leadfoot78's Avatar
Default Re: ITR LSD in GSR tranny? (IN VTEC)
I was told by a reputable source that the shims are needed only for after market LSD units.
Old Jun 27, 2003 | 03:13 AM
AWD: Jeff's Avatar
Default Re: ITR LSD in GSR tranny? (leadfoot78)
ive replaced mine, brand new from the dealer and im loving it.
Old Jun 27, 2003 | 07:15 AM
IN VTEC's Avatar
Maybe that's true, but the manual says you need to check and possibly adjust as well when you replace the diff or certain items centering around the diff.
syvlvr
Dec 11, 2006 10:24 PM
killacam20
Apr 12, 2005 09:13 PM
420aNT
Jan 23, 2003 04:09 PM
jArceo
Apr 23, 2002 08:33 AM
RedTeg95
Mar 20, 2002 06:30 AM
