ctr cams in gsr question.....
Old Jun 26, 2003 | 04:04 PM
genetsang's Avatar
Default ctr cams in gsr question.....
getting ctr cams.... with itr valve springs. and using stock gsr valves...... is there a break in period in these cams??? acutally, is there a break in period in new cams installs??
Old Jun 26, 2003 | 04:18 PM
civicVX's Avatar
Default Re: ctr cams in gsr question..... (genetsang)
i would give it 50-100 or so miles and then check your valve adjustment again. then your good to go.
Old Jun 26, 2003 | 04:20 PM
genetsang's Avatar
Default Re: ctr cams in gsr question..... (civicVX)
50-100 miles... at how high of revs.. and how fast....... would you recommend.
Old Jun 27, 2003 | 04:21 PM
civicVX's Avatar
as long as your valve adjustment is good to go. i would let ride. as in how high to rev. i wouldn't go over the stock rev limit on a gsr ecu.
boostedteg909
Nov 5, 2011 11:50 PM
flat-blk-HB
Jan 28, 2005 03:38 PM
tommyblaze
Nov 30, 2003 06:31 PM
Ryan C
11
Nov 25, 2003 06:35 PM
IgniteTeg
May 19, 2002 12:23 AM
