oil passage for middle main bearing...
Old Jun 26, 2003 | 01:45 PM
Greyout's Avatar
Default oil passage for middle main bearing...
I noticed that the crank does not have a hole in it on the middle main journal. The only oil passage is on the main cap. The rest of the main journals have holes in the crank and cap.
Why is this? It just so happens that the motor I am rebuilding has the most damage on that one journal.
Old Jun 26, 2003 | 02:36 PM
Greyout's Avatar
Default Re: oil passage for middle main bearing... (Greyout)
anyone?
Old Jun 26, 2003 | 06:58 PM
IloveNewt's Avatar
bump for a good Q.
Old Jun 27, 2003 | 06:34 AM
Greyout's Avatar
Default Re: oil passage for middle main bearing... (MordecaiPSI)
Old Jun 27, 2003 | 08:00 AM
apexii's Avatar
hrmm, interesting question. There has to be a logical reason though, I never noticed that....
Old Jun 27, 2003 | 08:31 AM
Greyout's Avatar
Default Re: oil passage for middle main bearing... (apexii)
Is the H22 one the same way? This is an H23.
Old Jun 27, 2003 | 10:42 AM
2point6's Avatar
The lubrication comes from the mains therefor it is not needed. The other passages are lubrication from the mains going to the rods.
Old Jun 27, 2003 | 01:31 PM
flyrod's Avatar
Default Re: oil passage for middle main bearing... (2point6)
It is interesting that the #1 and #5 journals are drilled, but #3 is not. Maybe the benefit of extra strength at the center of the crank outweighed the cost of redundant oiling. For instance, the #1 and #2 rods are fed from the #2 main journal, so drilling the #1 journal seems redundant, but it gets drilled. Anyway, if you are not following this, it's like 2point6 said: The holes are to get oil to the rods.
carlossolorzano
May 30, 2012 06:43 AM
jbrokos307
13
Oct 21, 2009 05:51 AM
xxmastermindxx
May 6, 2007 09:17 AM
ejcivicdee
Mar 30, 2006 07:38 AM
scratchy
Mar 17, 2004 02:49 PM
