Stage 2 cam shaft
Old Jun 26, 2003 | 07:25 AM
myh22's Avatar
Default Stage 2 cam shaft
i have stage 2 skunk2 camshafts, and i wanna know if i can run the cam shafts without having to redo the ecu. i got a race im going to soon, and id like to have the new valve train installed. can i do it or would it be harmful?
Old Jun 26, 2003 | 11:20 AM
LudeBehavior's Avatar
New User
Default Re: Stage 2 cam shaft (myh22)
In my opinion I would redo the springs and such to make it last longer and be more reliable. As far as the Ecu goes you could probally just take of the negetive lead and reset the ecu that way....
Old Jun 26, 2003 | 12:38 PM
myh22's Avatar
Default Re: Stage 2 cam shaft (LudeBehavior)
i alreday ordered the skunk2 valves, retainers, and valve springs. resetting the ecu would keep bad things from happening to the car???
Old Jun 26, 2003 | 01:00 PM
Behan's Avatar
when you say redo the ecu do you mean have it chipped? if so, then no you don't have to chip the ecu to run new camshafts. However you do need to have the car dyno tuned and the use of adjustable cam timing gears is also a must.
I'm guessin that you will have these installed by a performance shop? If so let them know of your concerns and ensure that the car will be dyno tuned. If your installing them yourself............... good luck.
Old Jun 26, 2003 | 08:46 PM
NXLude's Avatar
You will see minimal gains with no fuel tuning, like 5-8 hp at best.....youll be hella not tuned right
Old Jun 26, 2003 | 08:55 PM
2kflamedlude's Avatar
i dont know about skunk2s but.. I seen big gain with crower stage 2. yes I would get that car TUNED
Old Jun 27, 2003 | 07:45 AM
myh22's Avatar
Default Re: (2kflamedlude)
the problem im having, is that i dont know **** about the ecu. i know i need to upgrade, but can i get the factory unit reworked or can i use a piggy back system? Apexi VAFC??? or can honda redo my chip??? i simply cannot afford to pay 1000+ bucks for the aem unit but i also dont wanna try to cut corners and pay the price later. so i redo the ecu, how? and about how much will it cost. thanks guys.
Old Jun 28, 2003 | 05:38 PM
NXLude's Avatar
Default Re: (myh22)
vafc would be fine or an emanage, anything.....
Old Jun 28, 2003 | 05:58 PM
Default Re: (NXLude)
ONe of these days we are gonna line up.. 100 bucks..heh
Old Jun 29, 2003 | 05:32 PM
NXLude's Avatar
you better get me soon cause the cars gonna get way faster right quick......
91accordcandy
Oct 24, 2013 09:47 PM
maxx5905
Engine Management and Tuning
Apr 14, 2008 11:38 PM
xtegb16x
Jun 14, 2006 01:09 PM
myh22
Jun 16, 2003 07:11 PM
ramz7887
Jun 8, 2003 04:50 PM
