OBD1 fuel injectors vs OBD2 fuel injectors!!!
Injectors flow the same if they are B series. They are both saturated, but the difference is in the clips. OBD2 clips are bigger than OBD1 clips.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gram »</TD></TR><TR><TD CLASS="quote">no, OBD I is better.. do a search, this is all over the forums. If you have an OBD II you can make it an OBD I for not too much.</TD></TR></TABLE>
Little thing called "reading". Only difference in the injectors is the clips on the end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">
Little thing called "reading". Only difference in the injectors is the clips on the end.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=545019
https://honda-tech.com/zerothread?id=545019 </TD></TR></TABLE>
Look at the title of the post
