poor gas mileage. what could be the problem?
ok. my friend have a 94 ls (automatic). she's been complaining about shitty mileage (around 180 miles every tank). i changed the spark plugs, checked the timing..everything seems good. what else could cause shitty mileage?
Jeff-
Jeff-
damn. 180 a tank is really shitty. I assume you checked the air filter and tire pressure as well. Maybe it is just the stop and go traffic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra »</TD></TR><TR><TD CLASS="quote">O2 sensor...!
Almost definitely.
I agree. I think this might be it.
Almost definitely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional »</TD></TR><TR><TD CLASS="quote">Does her car bog??? If it does she should change out the primary o2 sensor in her exhaust manifold</TD></TR></TABLE>
But like he said, shouldn't that throw a code?
i just added a header and new bosch o2 and i didnt even get 180 to my tank
much worse gas mileage then before... didnt even get on it as hard as i normally do
tried resetting the computer but no luck.. no idea what to do.. maybe the bosch universal pos is the problem
i have a 93 ex auto
tried resetting the computer but no luck.. no idea what to do.. maybe the bosch universal pos is the problemi have a 93 ex auto
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Damn that really sux. Sorry to be a thread *****, but on my trip down to NC, I was gettin 35 miles to the gallon. All highway baby.
About a few weeks ago I went to the pump and filled her to the top. I have a 94 LS. After about two days I had to refill because I was at 1/4 tank. I was getting like 11 miles per galon. Like I was driving an H2 hummer. I check the everything. THe plugs are ok, filters, and everything else. When I check my fuel injection. And it was black as hell. I didn't even wanna try to clean it myself. I just took it to a local place had them do it for about 70 bucks. Afterwards. I was getting like 260 on ten gallons on a stock motor. Bro it's the fuel injections it must be dirty...
Give me a call asap. This **** is taking too long. I see you have time to post on H-T so I will be making a post about my expierence with you unless you can correct this situation by wed. Enough is enough. Chris
Dont' Change The Sensor! It's there to tell you that your car is having problem. Sounds like you just need to get a maintance if you have a poor gas milage. Depends if the car has high miles on it. Need to get your car Diagnose. And find out what's causing the sensor to come on. If you have a problem with a sensor use a digital multimeter and compare Spec's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xumarius »</TD></TR><TR><TD CLASS="quote">About a few weeks ago I went to the pump and filled her to the top. I have a 94 LS. After about two days I had to refill because I was at 1/4 tank. I was getting like 11 miles per galon. Like I was driving an H2 hummer. I check the everything. THe plugs are ok, filters, and everything else. When I check my fuel injection. And it was black as hell. I didn't even wanna try to clean it myself. I just took it to a local place had them do it for about 70 bucks. Afterwards. I was getting like 260 on ten gallons on a stock motor. Bro it's the fuel injections it must be dirty...
I was wondering about that...I had mine tune up wit most everything changed including the fuel filter, but gas mileage still sucked!! I used some Valvoline fuel injector cleaner and no luck...do those bottled fuel injector cleaner work at all?? or should I let the shop clean them??
</TD></TR></TABLE>I was wondering about that...I had mine tune up wit most everything changed including the fuel filter, but gas mileage still sucked!! I used some Valvoline fuel injector cleaner and no luck...do those bottled fuel injector cleaner work at all?? or should I let the shop clean them??
