V-afc wirring diagram
Old Jun 25, 2003 | 09:49 PM
SDT Project EF's Avatar
Default V-afc wirring diagram
Iam looking to instal a apexi v-afc. None of the wire diagrams in the manual that came with the v-afc match mine. I have 1990 civic with a 1995 d16z6. However, iam still using the stock d16a6 ecu. Does anyone know what wire to hook up where for this particular setup? Thanks
Old Jun 25, 2003 | 10:49 PM
Default Re: V-afc wirring diagram (SDT Project EF)
ttt
Old Jun 25, 2003 | 10:55 PM
Torino91LS's Avatar
shoot me an e-mail
I have a pdf file on the V-AFC for the USDm cars
Old Jun 25, 2003 | 11:15 PM
HandCommand's Avatar
I assume you are using your stock dizzy also, since you are retaining your PM6 OBD0 ecu?
I say you should get one of Jason's OBD0 to OBD1 conversion harnesses, use the stock D16z6 OBD1 dizzy and ECU. And let the OBD1 P28 ecu control the fuel maps and Vtec MADE for that engine.
It will run better than running that motor using the older OBD0 electronics and having the V-afc control the Vtec.
Honda did their homework. That engine will run best with the ECU and electronics it was designed for.
Make sure you use the appropriate injectors if you want to retain the injector resistor box.
Old Jun 26, 2003 | 03:23 PM
project dc2's Avatar
Default Re: V-afc wirring diagram (HandCommand)
this rides its being in use for the Vafc HACK .
Old Jun 26, 2003 | 03:28 PM
http://www.geocities.com/motor....html
there you go butt brain !
gonmaro
Engine Management and Tuning
Mar 20, 2009 12:42 PM
tigueremalo
Jul 21, 2006 10:51 AM
vw eater
Sep 15, 2005 01:31 AM
STREETWERKZ
Mar 25, 2005 08:22 PM
mz3bo
Feb 27, 2003 02:27 PM
