Ac and Ps pump/belts, where can i get them?
Anyone know where i can purchase a complete ac and ps fixtures? besides the dealership and a junkyard.
anyone have a guess on how much this should cost?
It can cost quite a bit if you need all teh lines and mounting hardware. Look around for some of the track ***** on here that have removed their PS and AC units.
Make sure you buy the PS pump that corresponds with the correct PS rack feed line. '94-'97 feed lines/pumps and '98-'01 feed lines/pumps are different where the line meets teh pump. The fitting to the rack is the same as well as the routing.
I've got a '94-'97 PS feed line and PS pump brackets if you happen to need them, but it's probably easier to find it all as a whole.
You can get the belts at Pepboys.
