Dyno results... Why so low #'s?
Alright guys i need you help... I have a 00Civic SI (b16a2) why where my numbers so low???
Engine Mods:
b16a2 with Drag kit (Turbonetics T3/T4B)
JE pistons 8.8:1 (compression test done before dyno 185psi across the board)
Eagle Rods
Hondata S200b
RC 440's
Walbro 255
Thermal 3inch with 2.5dp and 2.5 to 3inch test pipe
Aem fpr 1:1
running about 8.5psi-8.8psi
Final results: 199.1hp and 136.8tq
Modified by 9psiTurboSI at 4:42 AM 6/26/2003
Modified by 9psiTurboSI at 4:57 AM 6/26/2003
Modified by 9psiTurboSI at 5:22 AM 6/26/2003
Engine Mods:
Eagle Rods
Hondata S200b
RC 440's
Walbro 255
Aem fpr 1:1
If you can spring for it ($100.00) buy a Walbro 255lph and retune I would run 14lbs. You have the fuel, management and bottom end for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanEK »</TD></TR><TR><TD CLASS="quote">Jezz....I made 199.7whp and 135tq with my old N/A Ek hatch!
I am doing Turbo Si also, But i have decided to use the stock compression!
Eric
no kidding... i could have bought a JRSC and made the same #'s with the FMU
Eric
</TD></TR></TABLE>no kidding... i could have bought a JRSC and made the same #'s with the FMU
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI »</TD></TR><TR><TD CLASS="quote">
or you coulda ran the stock bottom end and made ~260-280
</TD></TR></TABLE>or you coulda ran the stock bottom end and made ~260-280
don't worry bro...i've got 8.8:1 pistons in my ls and i've got 155-160psi in all my cylinders and boosting 9psi i dyno'd at 210.6 whp and 193.2 wtq. i had originally thought i had 9.5:1 pistons until Boostfed told me that Ross did their calculations with a gsr motor/head which has higher compression. i also had my **** dyno'd at elite using uberchip and tuning with an afc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">
well i would have, but i busted 3 ringlands off 3 cyclinders... but i dun know what i was thinking when i went 8.8:1 (there actually stock bore JE GSR 9.8:1 but im pretty sure they 8.8:1 on a b16a2)... but ill take everyone's advise and turn the boost
Modified by 9psiTurboSI at 5:47 AM 6/26/2003
</TD></TR></TABLE>well i would have, but i busted 3 ringlands off 3 cyclinders... but i dun know what i was thinking when i went 8.8:1 (there actually stock bore JE GSR 9.8:1 but im pretty sure they 8.8:1 on a b16a2)... but ill take everyone's advise and turn the boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">don't worry bro...i've got 8.8:1 pistons in my ls and i've got 155-160psi in all my cylinders and boosting 9psi i dyno'd at 210.6 whp and 193.2 wtq. i had originally thought i had 9.5:1 pistons until boosted hybrid or someone else...i forgot, told me that Ross did their calculations with a gsr motor/head which has higher compression. i also had my **** dyno'd at elite using uberchip and tuning with an afc.</TD></TR></TABLE>
Hey that was me who gave you all the calculations! Give credit where credit is due!
It took me awhile to do all those calculations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">
whoops, sorry Boostfed...i knew it was boost+ something..., i'll go ahead and change that. thanks for helping me out earlier with those calculations!!
</TD></TR></TABLE>whoops, sorry Boostfed...i knew it was boost+ something..., i'll go ahead and change that. thanks for helping me out earlier with those calculations!!
Guest
Posts: n/a
well i would have, but i busted 3 ringlands off 3 cyclinders... but i dun know what i was thinking when i went 8.8:1 (there actually stock bore JE GSR 9.8:1 but im pretty sure they 8.8:1 on a b16a2)... but ill take everyone's advise and tune the boost
Its all good, i wouldn't mind have pistons/rods
Good luck with more boost
</TD></TR></TABLE>Its all good, i wouldn't mind have pistons/rods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">how much timing are you running?</TD></TR></TABLE>
its stock timing... is that good or bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">you arent taking any out per #?</TD></TR></TABLE>
left that to the tuner! your talking about timing right?
Modified by 9psiTurboSI at 5:47 AM 6/26/2003</TD></TR></TABLE>
Thats not true either. If they are 9.8:1 in a gsr they are something around 9.5:1 in a b16. I dont know what your problem could be.
It looks like it could use a little more tuning, but your low compression and lack of displacement along with the drag kit explains the numbers. The only way that setup is gonna make alot of power is with alot of boost...
??? just a guess, your really making the turbo do all the work with compression that low. Turn up the boost
