Question about swaybars......
I have a 99 civic CX hatch and I want to get front and rear swaybars for it because it handles like a turd
. I am torn between CTR front with ITR rear and a beaks kit with the OEM hardware, or a Suspension Techniques front and rear for a non-swaybar car. Which one would be the better choice as far as cost effective and performance wise? Let me hear your opinions so I can make the correct choice. Thanks.
i have the ST bars and i must say.. my hatch handles.. i have a 98.. if you were to do all OEM you would spend well over $300 where as the ST's are around $280 i believe.. go ST i have no complaints..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">i have the st front bar and itr rear bar with beaks kit on my 94 coupe but im changing the front bar to oem... honda tuned these bars from the factory, dont **** with the balance.
I disagree on the balance issue. ST is tuned as good if not better in my opinion, but if you want to go oem fronts get them from me please.
</TD></TR></TABLE>I disagree on the balance issue. ST is tuned as good if not better in my opinion, but if you want to go oem fronts get them from me please.
I picked up a cheap set of ST sways off of ebay, just keep your eyes out. I payed $190 shipped for them brand new. I kept the front bar but ditched the rear because it is necessary to drill your subframe to get it to work. I just went with a Skunk2 rear swaybar instead, its a lil thicker and wont weaken the subframe. Rick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveHonda »</TD></TR><TR><TD CLASS="quote">Do you know what the diameter of the ST bars are?</TD></TR></TABLE>
Not sure on the front bar, but the rear is 21mm.
I'm in the sambe boat as you are right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickChew »</TD></TR><TR><TD CLASS="quote">I picked up a cheap set of ST sways off of ebay, just keep your eyes out. I payed $190 shipped for them brand new. I kept the front bar but ditched the rear because it is necessary to drill your subframe to get it to work. I just went with a Skunk2 rear swaybar instead, its a lil thicker and wont weaken the subframe. Rick</TD></TR></TABLE>
You will have to drill the subframe regardless of what swaybar you put on. I had to drill out some holes in my Integra to mount the ITR rear sway bar.
My friend has ST bars front and rear on his 95 DX coupe. They're alright I guess, but the way they mount onto the car SUCKS in my opinion. The way the ends of the bars are shaped and the way they bolt to a bracket on the lower shock fork just doesn't do it for me. Also the front bar passes UNDER the exhaust and everything else
Needless to say he is getting everything needed (control arms, etc.) to be able to install a front ST bar made for an EX, and also an OEM ITR rear bar.
klomast3r
Nov 5, 2005 04:08 PM
VSMHatcH
Aug 29, 2004 10:52 AM
