Possible to put S2000 cluster in 00 SI?
Old Jun 25, 2003 | 12:48 AM
Takashi1978's Avatar
Default Possible to put S2000 cluster in 00 SI?
I might be able to obtain a used S2000 cluster for cheap.Has anyone tried to install the S2000 cluster in their 00SI?
How hard is the install?
Anything i should look out for?
Any pics?
Old Jun 25, 2003 | 01:02 AM
Kamin's Avatar
Default Re: Possible to put S2000 cluster in 00 SI? (Takashi1978)
dosent work.
the tach and spedo are completley diffrent systems.
Old Jun 25, 2003 | 10:21 AM
Default Re: Possible to put S2000 cluster in 00 SI? (Kamin)
Anyone else can confirm this?
Old Jun 25, 2003 | 10:24 AM
allmtr's Avatar
never tried it or know anyone who has... if there are pins then im sure you might be able to repin it like ppl do for the integra cluster in a civic. but the gauges on an s2 are digital so im having doubts
COMplex.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takashi1978 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else can confirm this? </TD></TR></TABLE>
try.
find out.
let us know!!
Old Jun 25, 2003 | 10:25 AM
tominos's Avatar
i remember seeing someone install it into their eg or ek, but they couldn't get the speedo to work.
Old Jun 25, 2003 | 10:47 AM
Trooper's Avatar
Couldnt you use some sort of pulse converter to conver the VSS signal to the S2k vss signal?
Old Jun 25, 2003 | 11:11 AM
EG(6)SR's Avatar
Default Re: Possible to put S2000 cluster in 00 SI? (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos &raquo;</TD></TR><TR><TD CLASS="quote">i remember seeing someone install it into their eg or ek, but they couldn't get the speedo to work.</TD></TR></TABLE>
ditto...
Try it out, personally since the 99' si has already a nice gauge cluster, I wouldn't fool around with it, (CX/DX hell yeah I would). Let us know if you do it....
moneymaker42141983
Sep 11, 2012 04:22 PM
MrHatchy
Dec 2, 2011 11:12 AM
xxdevilzeroxx
Mar 1, 2010 05:30 AM
crx^2yosolo
14
Dec 27, 2005 05:42 PM
