Car is shakin
Old Jun 24, 2003 | 11:14 PM
BabyInteg's Avatar
Default Car is shakin
I was driving down my street and my car starts shakin and i pull over and pop the hood check all the spark plugs and there all fine go i go to advanced and get carb cleaner and i spray all my vaccum lines and i spary one of them and the car dies and i have a vaccum leak is it common for a car 2 do that?!?!?!??!
94 Ls Integra
Old Jun 24, 2003 | 11:18 PM
Loveless's Avatar
Default Re: Car is shakin (BabyInteg)
how you know it has a vacuum leak?
what do you mean the car just die? no spark? crank but won't start?
Old Jun 24, 2003 | 11:20 PM
BabyInteg's Avatar
Default Re: Car is shakin (Loveless)
The carb cleaner gets in the **** and cleans it all up and if it the car dies that means theres a leak thats why it would die it would start and everything
Old Jun 25, 2003 | 08:35 AM
IntEGNYC's Avatar
You should get it towed to a mechanic and have it checked out. it doesnt sound good.
Old Jun 25, 2003 | 07:03 PM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BabyInteg &raquo;</TD></TR><TR><TD CLASS="quote">I was driving down my street and my car starts shakin and i pull over and pop the hood check all the spark plugs and there all fine go i go to advanced and get carb cleaner and i spray all my vaccum lines and i spary one of them and the car dies and i have a vaccum leak is it common for a car 2 do that?!?!?!??!
94 Ls Integra </TD></TR></TABLE>
if the vacuum line you sprayed is made of rubber, try checking it to see if it has a hole or is cracked.... or just replace it with some from the parts store and see if that fixes your rough running car. good luck.
Ventolin
29
Oct 16, 2009 07:33 PM
TheSiWay
Jun 21, 2008 07:21 PM
danny_ha
16
Jan 13, 2008 07:42 PM
Lokisdope
Nov 21, 2007 06:26 PM
