what size deep socket to remove oil switch??
Old Jun 24, 2003 | 11:01 PM
SHystrdyGSRtdy's Avatar
Default what size deep socket to remove oil switch??
99 gsr...what size deep socket size did you guys use to remove the oil switch??!?!
Old Jun 25, 2003 | 12:33 AM
eg6beater's Avatar
Default Re: what size deep socket to remove oil switch?? (iLUVmySH)
i thought it was a 23 mm the last time i removed mine from the b16.....supposed it's all the same.....but do post if you find something different...all i know is that it's a big size
Old Jun 25, 2003 | 03:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLUVmySH &raquo;</TD></TR><TR><TD CLASS="quote">99 gsr...what size deep socket size did you guys use to remove the oil switch??!?! </TD></TR></TABLE>
15/16
Old Jun 25, 2003 | 08:31 AM
Default Re: what size deep socket to remove oil switch?? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
15/16</TD></TR></TABLE>
thanks for the help..time to buy a deep socket....how did you guys get the line on tight after removing the oil switch tho? cuz with a socket....the line gets in the way....
Old Jun 25, 2003 | 08:33 AM
did you guys use the through ratchet set where there's a big hole in the middle or will a reg deep socket work?
Old Jun 25, 2003 | 12:40 PM
Chiovnidca's Avatar
....how did you guys get the line on tight after removing the oil switch tho? cuz with a socket....the line gets in the way....</TD></TR></TABLE>
Do you mean the wire? You have to unplug it.
Old Jun 25, 2003 | 12:46 PM
3rdGteg's Avatar
Do you mean the wire? You have to unplug it. </TD></TR></TABLE>yeah, just pull it off like a plug...
Old Jun 25, 2003 | 05:30 PM
Default Re: what size deep socket to remove oil switch?? (3rdGteg)
no..not that line..i'm talking about the oil line to attatch to the tee... how did you fit the socket over the bspt/npt fitting with the copper or nylon line hooked up to it?
Old Jun 26, 2003 | 03:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLUVmySH &raquo;</TD></TR><TR><TD CLASS="quote">no..not that line..i'm talking about the oil line to attatch to the tee... how did you fit the socket over the bspt/npt fitting with the copper or nylon line hooked up to it?</TD></TR></TABLE>
Use an openend wrench.
ctr83
Oct 10, 2008 06:22 PM
El pimp chulo
Aug 8, 2006 05:45 PM
huge230
Mar 7, 2006 09:44 AM
TurblowR
Jun 28, 2004 04:13 PM
choiboiracing
Feb 1, 2004 09:07 PM
