Need help ASAP with brakes... stuck ?
Old Jun 24, 2003 | 09:08 PM
DUCK COMMANDER's Avatar
Default Need help ASAP with brakes... stuck ?
Ok i changed my pads and rotors on the back last night and i knew that the left rear never had worked right while i had the car.
But i thought it might have been the pads or something.
Well I put the new stuff on and go drive around but the left rear is i guess sticking.
After driving less than a mile the brake is almost smoking when i come to a stop.
I notices that the top bolt that holds the caliper on does not move in and out like the botton and it does not spin. (this is the bolt with the rubber boot on it. I think that this means i need a new part.
Am I right, I really dont have money to buy what i dont need.
Please help out.
Thanks,
Jeremy
Old Jun 24, 2003 | 09:17 PM
Dan GSR's Avatar
Default Re: Need help ASAP with brakes... stuck ? (JSutterEH2)
you can try taking out the slide pin...the one that isn't moving...clean it up and grease it ...you will also need to bleed your brakes, as you probably boiled the fluid
Old Jun 25, 2003 | 03:55 AM
ttt please..thanks
Old Jun 25, 2003 | 04:11 AM
MrJasey's Avatar
you need to either rebuild the calipers or order new calipers because the pistons are siezed and frozen
Old Jun 25, 2003 | 05:27 AM
Rory Breaker's Avatar
Default Re: (MrJasey)
That pin was frozen out on my caliper as well. I took it off and with a swift smack with a sledgehammer that changed real quick. Slides in and out nicely now
Old Jun 25, 2003 | 05:17 PM
Default Re: (newgsrdriver)
well i hit it with everyting i had but never broke loose..but i got another one at the junkyard for 10 bones...back on the road woohooo
Old Jun 25, 2003 | 07:42 PM
DEVIN22CBR's Avatar
Default Re: (JSutterEH2)
I highly doubt you did
square_1
16
May 7, 2007 12:01 AM
integra3g
May 18, 2006 06:48 PM
afhockeyfreak4ml
Jul 24, 2004 05:01 PM
lazynok
May 17, 2004 03:42 PM
LudeBehavior
Feb 8, 2002 12:49 PM
