rear disk on dx with no ex master/booster and prop. valve???
I got the trailing arms, e-brake cables, and brake lines. The donor car had abs and the brake booster was leaking, so i don't have master/booster and prop. valve. what will happen if i put the brakes on with out that stuff? Has any one ever done that? What model car can i find the prop. valve in?
you are fine.. you wont have the full potential that rear disc can give with out the correct prop valve... mc and booster give better pedal feel, and more sensitive braking
The disk setup wants more fluid to lock it up. THe fronts will lock up long before the rears will with your old prop valve
89efDUSTY
13
Mar 26, 2007 11:20 PM
crexer
Aug 17, 2004 05:26 AM
