how do you make an Ls motor a vtec?
Old Jun 24, 2003 | 08:59 PM
kane4abel's Avatar
Default how do you make an Ls motor a vtec?
Im really interested into swapping a ls motor into my 94 coupe. How do you make the ls motor a vtec?
Old Jun 24, 2003 | 09:46 PM
Spirit Iron knife's Avatar
Default Re: how do you make an Ls motor a vtec? (kane4abel)
Ummm, add a Vtec head, and wire up the Vtec?
Old Jun 24, 2003 | 10:02 PM
TheHooded_Mike's Avatar
Default Re: how do you make an Ls motor a vtec? (Cult of Staxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cult of Staxx &raquo;</TD></TR><TR><TD CLASS="quote">Ummm, add a Vtec head, and wire up the Vtec? </TD></TR></TABLE>
Ya 'cause it's that easy right? No. Well even I have no experience in this but I could atleast point you in the right direction. Go to g2ic.com, go to teg tips on the top scroll tab, then click under engine and it says LS/VTEC conversion. That should help, plus it has pictures. ...And if that isn't enough, search because I'm sure this has been covered a million times and then some.
Old Jun 24, 2003 | 10:05 PM
JasonBlackEJ1's Avatar
Default Re: how do you make an Ls motor a vtec? (TheHooded_Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheHooded_Mike &raquo;</TD></TR><TR><TD CLASS="quote">
Ya 'cause it's that easy right? No. Well even I have no experience in this but I could atleast point you in the right direction. Go to g2ic.com, go to teg tips on the top scroll tab, then click under engine and it says LS/VTEC conversion. That should help, plus it has pictures. ...And if that isn't enough, search because I'm sure this has been covered a million times and then some. </TD></TR></TABLE>
Old Jun 24, 2003 | 10:16 PM
WongFeihung's Avatar
Default Re: how do you make an Ls motor a vtec? (JasonBlackEJ1)
best way to go is Search my friend. there are thousands of posts relating to this topic. good luck.
Old Jun 25, 2003 | 01:20 PM
-Trinitron-'s Avatar
try the all motor forum...always good stuff.
wastedyouth2542
Jul 19, 2007 05:20 PM
WhoneedsVtec7g'sISplenty
Mar 14, 2006 10:07 AM
RSNTEKRA
Oct 3, 2005 10:58 AM
Spoogen_1
76
Jan 7, 2005 01:26 PM
GhettoR
Nov 3, 2004 02:08 PM
