Tranny Question
Old Jun 24, 2003 | 08:30 PM
501 Lude's Avatar
Default Tranny Question
I'm trying to get a 5 speed swap and I've found a Type SH tranny for sale with atts for 700 bucks. My question is can I use the transmission without the atts or should i look for a base 5 speed?
Old Jun 24, 2003 | 09:27 PM
AznPimpS's Avatar
get a base 5 speeds
there just too much wiring for ATTS
adding this and that
base 5 speed with some good syncros
gear set
and a fine LSD will do you good
Old Jun 24, 2003 | 09:41 PM
501 Lude's Avatar
Default Re: (AznPimpS)
I don't want atts, could i not just take off the atts and not worry about it? I thought base and the sh had the same tranny just atts was added. **** that pisses me off if they are different. Please tell me they aren't and i can have a nice, clean, easy swap.
Old Jun 25, 2003 | 07:58 AM
AznPimpS's Avatar
http://www.collectiveracing.net
ya might have to register to view the board
but there's a good topic in "prelude" about tranny
and no ATTS is an add-on take it out
the only tranny that differ is the M2B4 LSD's and non LSD's
good luck
Old Jun 25, 2003 | 08:06 AM
Kal's Avatar
Kal
Default Re: (501 Lude)
i believe the SH tranny is different. It cannot be used on a base block, the SH uses a special block that fits onto the tranny, the SH tranny will not bolt on. Correct me if i'm wrong
Old Jun 26, 2003 | 01:04 PM
kotetu's Avatar
Default Re: Tranny Question (501 Lude)
the SH tranny won't fit without the ATTS unit, and probably axels. Someone should correct me here.
Anyway, if you are doing the swap for a 5th gen, you should get a base model transmission. Try to do what I did and get a 4th gen transmission with low miles on it. The 4th gen gears are shorter (faster acceleration).
Do you need the 5speed guage cluster? I have an extra one for 5th gen. let me know.
scootertribe
May 10, 2005 06:24 AM
Creator
Oct 9, 2004 02:36 PM
Creator
Oct 9, 2004 11:30 AM
