H22 H23 VTECH QUESTION
Old Jun 24, 2003 | 08:29 PM
smp1's Avatar
Default H22 H23 VTECH QUESTION
OK I have a 94 H22 complete motor and a 93 H23 complete bottom end. I am going to do a frankenstein using stock parts in both blocks to build a strong, daily driver T3 turbo motor (8lbs.)(at least as strong as I can get). So using the stock parts which pistons, rods, crank etc. should I use to get lowest compression, strongest and make the most power.
Old Jun 24, 2003 | 09:04 PM
smp1's Avatar
Come on guys help me out. bump before bed
Old Jun 24, 2003 | 09:29 PM
skrewdlude's Avatar
Default Re: (smp1)
1. it is vtec.
2. look at the sticky on the top of this forum.
Josh
Old Jun 24, 2003 | 09:35 PM
sam187p's Avatar
Default Re: (smp1)
seems like a lot of work...i'd just be happy with the h22, but hey whatever floats your boat. And can someone tell me if his year h22 has an open or closed deck??if it's closed then you'll have a strong engine anyway( with some forged internals you'll be a lil safer but it doesn't seem like you want that)...its not worth all the trouble for 100cc's more.
Old Jun 24, 2003 | 09:36 PM
JG Luder's Avatar
Default Re: (smp1)
I'm still wondering how in the hell you missed this:
https://honda-tech.com/zerothread?id=510617
I mean really... we made it DUMB kinda easy to find. It's the second thread from the TOP.
Old Jun 24, 2003 | 09:48 PM
irishpilot's Avatar
basically with wanting to go with boost
you would want to do this:
Use H23a block- Keep stock pistons but I would pull them and hone the block replace the bearing and put in new piston rings to get a good seal.
Also, for the Timing belt use the H23 manual tensioner- you can search for info on this- basically it keeps the T belt where it should be!
Also, with a stock Head gasket with the H22
head (satan srv) calculated that you should have 9.3 to 1 compression. to get it a littly lower I would use a thicker head gasket. I would ask the people in FI thread about this.
Then for the head itself keep the stock cams
you COULD if wanted p&p the IM and throttle body for some more air and fuel for the boost
AND you should/probaly know this- Engine Managment is crutial with the H series and boost!!! Get bigger injectors, Walbro 255lph fuel pump and then the FMU to keep fuel demands met at boost. And then you would want of course at least a VFAC if not a Hondata
system to keep it running reliably.
But this will save you about $2000 in bottom end work and forged parts- but it is not as bullet proof. ALSO- your going to HAVE to keep the RPM's down to what the si redline is 6500
because with the boost you'll be runnin HOT
goodluck
Old Jun 24, 2003 | 10:37 PM
satan_srv's Avatar
Default Re: (irishpilot)
using H23 pistons, rods and crank will give you the lowest CR with stock internals. Since the H23 is 9.8:1 when you slap a VTEC head on it the increased combustion chamber size drops CR to 9.3:1 ish..
I am guessing you are well aware that boosting over 7-9 psi on a stock H series is risky..I suppose 8 is okay, but you have been warned, prelude ringlands are weak!
Old Jun 25, 2003 | 01:25 AM
ichibanjap's Avatar
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">I suppose 8 is okay, but you have been warned, prelude ringlands are weak !</TD></TR></TABLE>
When i pulled mine for a rebuild, the ringlands in two of the pistons were broken. More than 8lbs and your pistons will be toast.
Old Jun 25, 2003 | 02:44 AM
ITR632's Avatar
Thanks guys now I know where to start. Anything else let me know.
Old Jun 25, 2003 | 04:16 AM
Boostless97Lude
Guest
Posts: n/a
Default Re
you are an idiot, i can't believe you missed the damn thread stickied to the top od the page, how about you open your eyes next time before you create a new thread, and USE THE DAMN SEARCH FUNCTION
oh, yeah, and you are an impatient tool, you bumped the thread after 30 min, at 12:30 AM EST, there ein't enough trafic in this forum to need to bump something
Old Jun 25, 2003 | 04:34 AM
CHK4TIX's Avatar
Default Re: (Boosted97Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">
you are an idiot, i can't believe you missed the damn thread stickied to the top od the page, how about you open your eyes next time before you create a new thread, and USE THE DAMN SEARCH FUNCTION</TD></TR></TABLE>
i second this
Old Jun 25, 2003 | 08:07 AM
AndyD's Avatar
Default Re: (CHK4TIX)
Well I have a question. If I put an H22 intake manifold on my H23 will that give me VTAC?? If it does, I am going to put a "Powered by VTEK" sticker on my car.
Oh, and I have already searched for this but I came up with no results.
Old Jun 25, 2003 | 06:40 PM
smp1's Avatar
Default Re: Re (Boosted97Lude)
ooh you are hard core sittin behind the computer talking $--t about people. YOU ARE HARD CORE. For your info. I did see the thread but 100 people said 100 diffrent things which was said to be wrong by somebody else. But I didn't know that you were the h23 vtech master, my bad I guess I didn't see that either. But I found out what I needed to know so, PEACE
Old Jun 25, 2003 | 06:48 PM
poison's Avatar
Default Re: Re (smp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smp1 &raquo;</TD></TR><TR><TD CLASS="quote">ooh you are hard core sittin behind the computer talking $--t about people. YOU ARE HARD CORE. For your info. I did see the thread but 100 people said 100 diffrent things which was said to be wrong by somebody else. But I didn't know that you were the h23 vtech master, my bad I guess I didn't see that either. But I found out what I needed to know so, PEACE </TD></TR></TABLE>
LOL!
*gasp* OMG.
That was a nice laugh.
Thank you for making my day.
Old Jun 25, 2003 | 06:49 PM
PetroGuyX's Avatar
i'm not gonna flame you, but VTEC, not VTECH
Old Jun 25, 2003 | 07:17 PM
JG Luder's Avatar
texas heat wave... end of july... austin texas
I'll be there.
I'll talk **** to your face. Now... shut the **** up.
Old Jun 25, 2003 | 07:22 PM
smp1's Avatar
Default Re: Re (Lone Luder)
ooh we got another GANG MEMBER who has to have the last word. I'm done with this BIG dick contest you are cooler than me. Scared to lick the P---Y so you eat around the tush. GANG MEMBER
Old Jun 25, 2003 | 07:24 PM
Boostless97Lude
Guest
Posts: n/a
bwahahaha
dumbass n00b
get a life
Old Jun 25, 2003 | 07:25 PM
JG Luder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smp1 &raquo;</TD></TR><TR><TD CLASS="quote">ooh we got another GANG MEMBER who has to have the last word. I'm done with this BIG dick contest you are cooler than me. Scared to lick the P---Y so you eat around the tush. GANG MEMBER</TD></TR></TABLE>
Yes, I do have the bigger dick. I am the better person. I know more than you. I'm smarter, I have a faster car, and I could probably kill you barehanded.
It's for the best that you have given up.
Gang member. LOL. I don't need gangs. I can hold my own mother ******.
Old Jun 25, 2003 | 07:28 PM
Boostless97Lude
Guest
Posts: n/a
hehehehe
to be honest, there are a more than a few of us in here that could make you cry from how ignorant you would feel after trying to start a war with us
Old Jun 25, 2003 | 07:32 PM
AndyD's Avatar
Dude, the best advise I can give you is search before you post. If you find a post pertaining to something you have a question about post in THAT thread. Someone will respond.
This is a great place for answers to your questions. This is the only place I have found that has members concerned about the performance of their cars, not how it looks. You will definately find someone who has already done what you are THINKING about doing. Just search first. That way it keeps all the information about that issue in the appropriate threads.
Just let it go and participate on this site in a positive manner.
Old Jun 25, 2003 | 08:02 PM
poison's Avatar
ROFL.
omg, sam and todd, you two are killing me.
*gasp*
Old Jun 25, 2003 | 09:35 PM
irishpilot's Avatar
Lone Luder:
Did you ever finish your car after the Gumball?
I'd like to see what number it would have made in comparison with the porsches and ferrari's. I watched the mischief 3000 and seen the F50 do 184--pretty tight!!!
Boosted97Lude- I seen your pics very nice!
Old Jun 25, 2003 | 10:29 PM
JG Luder's Avatar
The F50 wasn't ****. Nice car, great guy who owned it.... but...
The CC85 hit a documented 243 mph on I-10 in Texas.
That also happened to be the day he was pulled over numerous times, given 8 seperate tickets, and arrested 3 times.
But he hit 243...
Old Jun 26, 2003 | 09:23 AM
optikal_blitz's Avatar
Default Re: (Lone Luder)
how fast did you get her rollin Lone? do you have any pics from the experience or did i miss that thread?
