Roof Gutter Replacement
I have the CRX manual on CD but I don't think it shows how to remove/install the roof gutters on the CRX. I read on crxsi.com forum that some guy had the same leak problem out of the hatch and replaced the gutters. That eliminated his hatch leaks amongst other things. I gutted my whole roof interior and found the water was in fact running from where the gutters were on the outside towards the back of the car, leading to the hatch struts. Anyone know how difficult it is to replace these things? I already ordered 2 of them from Honda and will have it by Fri.
I found this in crxhondaperf, but I don't understand where the "hatchjamb" is or where on the hatch this is. I need to fix this problem soon because Fla is now in it's rainy season and it sux having water drip all on the rear speakers.:
"Question: What causes almost every crx to leak when it rains. I have a 91 DX without
a sun roof. Could the lil plastic tubes be clogged from that hatch drain.
Every one's Crx around here has the same problem. It dont think its
leaking from the hatch seal. Any info appreciated.
Answer: After removing and replacing the sunroof in my 91 Si, I found it
wasn't the problem. Turns out the seam where the roof panel is
welded to the quarter panel of the car was causing the problem.
At the factory the two panels are spot welded togther and the
small gap left is filled with body sealer. As time goes by the
sealer hardens and then cracks allowing water to enter the
seam and get inside the car. I used some 3M "Heavy Drip Check
Sealer" to fix mine, it's available at autobody supply stores.
The seam is at the top two corners of the hatch jamb. The two
black black thingies that run the length of the roof conceal the
weld between the two panels. My car was leaking at the very end
of the passenger black strip right at the end. I popped off the
black thing with a small flatblade screwdriver and cleaned out
the crud in there, then applied the sealer over the old cracked
sealer. This stopped the leak for a few months, but now it's
back. (Although not as bad.) The proper way to fix this is to dig
out all the old crusty sealer, prime it with catalyzed primer and
then reseal the seam. I may do this before I repaint my car.
Hope this helps!"
any idea what part of the hatch he's talking about? Any pictures?
Hope this helps!"
