Tokico Coilovers, yae or nae?
I'm looking for a suspension now and i was wondering if anyone here has the tokico coilover kit. the one that has the built in spring adjustment sleeve paired with tokico illumina 5 way shocks and how they like them, or IF they like them.
Also, does anyone know the spring rate for the tokico springs used in this app?
-ryan
EDIT: did a search but couldn't find the exact spring rate, all i got was "something around 400lb/in" is it closer to 300 or closer to 500?
-ryan
Modified by tegasaurus at 7:37 PM 6/24/2003
-ryan
-ryan
Never personally had them but I do have the illumina shocks paired up with skunk2 coilovers. Any spring\shock combo under a reputable name is usually going to give you a well balanced ride. If the price is right I give it a yae.
i see... so how do you like the setup? what settings do you roll around town on and does it bounce like evyerone says the skunk2s do?
-ryan
-ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonoknut »</TD></TR><TR><TD CLASS="quote">ebay coilovers
i hated installing those....
right now i am riding on illuminas and ground control coilovers. once i get it all set, and the corner weights were i want them it will be awesome. right now i just adjust it by eye, and it works pretty good. i cant imagine that gc and skunk 2 are that different. just dont use a real still shock setting with a low spring rate...
