Power steering pump
Old Jun 24, 2003 | 04:33 PM
jf2381's Avatar
Default Power steering pump
Hi, I have a 2001 4cyl accord rolling on 19x8.0 Wheels and a eich springs and tokico shocks setup. My problem is that when I turn my steering wheel it's hard like if my power steering pump wasn't working. Is there a sensor that activates the pump when i turn the steering wheel or is it my pump that's f***ed up? If the pump fried i'm thinking it's because of the wheel size. Is there a pump upgrade, or can i use the pump from the v6 or the TL/CL?
Thanks in advance for your help.
Old Jun 24, 2003 | 06:29 PM
all420's Avatar
Default Re: Power steering pump (jf2381)
19" wheels with a drop. Hmm, you sure you're not rubbing?
But, to try and help you out further, check your belt for tension.
Old Jun 24, 2003 | 07:13 PM
ichibanjap's Avatar
Default Re: Power steering pump (all420)
I would check to see if your tire is hitting anything in the wheel well before you say it's your p/s pump. What size are your tires?
Old Jun 25, 2003 | 02:42 AM
jf2381's Avatar
I took the front wheels off and put the stocks back on. It's drop but i still have like two finger gap between the wheel weld and the tire. The belt is fine.
crispycjb
Mar 8, 2015 10:30 PM
tha_mann
Dec 31, 2011 04:10 PM
ktwanky
Oct 30, 2006 05:13 PM
cd6SiR
Apr 20, 2005 07:13 AM
