Swaping Headlights on an 90 civic Si???? ASAP!!!
Old Jun 24, 2003 | 04:00 PM
IEATLINT's Avatar
Default Swaping Headlights on an 90 civic Si???? ASAP!!!
my friend and i are trying to remove the headlight from his 1990 civic si, and we've gotten the top two bolts and side bolt under the coner light. where is the last bolt?????? do you have to remove the bumper to get to it???? thanx in advance.
Devin
Old Jun 24, 2003 | 04:03 PM
redcivic90's Avatar
Default Re: Swaping Headlights on an 90 civic Si???? ASAP!!! (IEATLINT)
yes, remove the bumper to get at the bolts underneath. i also found it much easier to remove the metal filler piece above the bumper to slide the headlight assembly out.
Old Jun 24, 2003 | 04:04 PM
IEATLINT's Avatar
Default Re: Swaping Headlights on an 90 civic Si???? ASAP!!! (redcivic90)
thanx alot
Old Jun 24, 2003 | 04:09 PM
IEATLINT's Avatar
i feel like an idiot, but how do you remove the bumper???? where are the bolts?
Old Jun 24, 2003 | 04:17 PM
tysf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IEATLINT &raquo;</TD></TR><TR><TD CLASS="quote">i feel like an idiot, but how do you remove the bumper???? where are the bolts?</TD></TR></TABLE>
im just going by memory but.... remove the bumper lights, there are two bolts behind each light i believe there are 3 bolts that hold the bumper at the bottom (they should be easy to find if you note where the plastic bumper cover ends) then there are 2 screws on each side in the wheelwell.
Old Jun 24, 2003 | 04:18 PM
0554's Avatar
easiest way to remove the bumper is to take out the bumper lights and just unbolt the core support. there are two bolts behind each bumper light. and of course unbolt from the fender area. hope i could help
Old Jun 24, 2003 | 04:19 PM
shoden's Avatar
They're located behind the front turn signals... the ones in the bumper, not the corner lights. Remove those lights, and there's a couple of bolts on each side.
ryan_crx
Apr 24, 2009 07:42 AM
racerxfactor
Mar 12, 2007 05:08 AM
richboi
Mar 15, 2006 04:14 PM
technine
Mar 26, 2002 11:22 AM
wickedxbo1
Aug 23, 2001 08:45 PM
