Motor Mount Symptoms?
OK, i'm tryign to narrow down my problems. . can some one give me a list of symptoms on what happens when a motor mount goes out. . also, is the front mount really important on a 90 LS/RS/GS integra??? will it hurt anythign if its not there? i know the EG's dont have them. . . HELP!!!
You can see the front mounts from up top of the engine bay, and the bottom ones are pretty easy to inspect as well. Just a few 10mm bolts you have to remove the skidplate to view them.
Just make sure the rubber around them has not torn, or looks old and cracked.
Mine were in pretty bad shape on a 96, so some inserts really helped stiffen things up.
