H22 EJ6 Failed Emissions, But Why? Take a Look!
Old Jun 24, 2003 | 02:56 PM
junglerunna's Avatar
Default H22 EJ6 Failed Emissions, But Why? Take a Look!
Standard - Reading
Nox - 828 - 2500 - Fail
HC -100 - 160 - Fail
CO% - .56 - .57 - Fail
The car is a 99 civic dx, with a 94 JDM H22. They did not say anything to me or on the paper saying that the car was converted to OBD1. Although Im not sure what to here. I have AEM ITR CAI, headers, Carsound cat,and Apex N1 exhaust. Im almost postive Apex makes 50 state legal exhaust. I might be wrong though. Any one have any suggestions as of why I failed emissions in New Jersey so bad.
Old Jun 24, 2003 | 02:57 PM
NonovUrbizniz's Avatar
Loved
Default Re: H22 EJ6 Failed Emissions, But Why? Take a Look! (junglerunna02)
maybe it's because you're being held to 1.6l restrictions and you have 2.2liters...
"that's more fuel to you and me russ."\
that and you didn't mention if or what cat you are running...
oh and how did you manage to get "headers" on your car???
Old Jun 24, 2003 | 03:00 PM
Default Re: H22 EJ6 Failed Emissions, But Why? Take a Look! (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">
oh and how did you manage to get "headers" on your car???</TD></TR></TABLE>
Carsound Cat Im running.
I could I have not put headers on my car? They are some JDM type headers, that came with the swap.
Old Jun 24, 2003 | 03:04 PM
RSZero1's Avatar
He's messing with you,
"That's HEADER to you and me russ"
Our cars run 1 HEADER, not a set of headers plural.
Old Jun 24, 2003 | 03:09 PM
Default Re: H22 EJ6 Failed Emissions, But Why? Take a Look! (RSZero1)
Oh, haha I should have picked up on that considering Im taking a summer English one class right now. Anyways, does anyone have any advice.
Im throwing EGR code if that helps.
Old Jun 24, 2003 | 03:18 PM
Loved
the egr being bad could cause you to run rich... that would fail you.
i just seached egr and one of the posts said he was running rich as a result of bad egr...
Old Jun 24, 2003 | 03:21 PM
Well my EGR system is not even hooked up. Which by my NOx results being so high, would mean that I might be running rich.
Old Jun 24, 2003 | 03:23 PM
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">Well my EGR system is not even hooked up. Which by my NOx results being so high, would mean that I might be running rich.</TD></TR></TABLE>
I'm not sure then because lots of people are running them w/o... so if it's not a bad valve mis-functioning I don't know if it will just run rich by default...
search around a bit I'm sure the answer is out there... also try the hybrid forum.
Old Jun 24, 2003 | 03:30 PM
Well the this forum gets more traffic from all users so I put this in hear. I wait it out for the rest of night to see if I can get some more insight. If not Ill ask Tom to move it to the Hybrid forum.
Old Jun 24, 2003 | 03:32 PM
Caveman74's Avatar
All you readings are really high. in Ga these are the Allowable rates. On the right are Mine
HC-ppm -167 -- 50
CO-% 0.94-- 0.04
NO-ppm 1240-- 0187
It might by your O2 sensor or you might want to lean your car out. We also have to put our cars on DYNOS @ 25 mph for 4 min. Sucks
Old Jun 24, 2003 | 03:37 PM
Default Re: (Caveman74)
I might be wrong but if my O2 sensor is bad wouldnt it through a code?
Yeah in NJ cars go up on a dyno also, Im sure if its 4 mins though, thats real long.
Old Jun 24, 2003 | 03:47 PM
Caveman74's Avatar
Yeah it sucks. True on the O2, May be your cat?
Old Jun 24, 2003 | 03:50 PM
Carsound cat is less than a month old. I put about 300 miles a week on the car if that. The cat maybe has a 1000 miles on it.
Old Jun 24, 2003 | 03:55 PM
poison's Avatar
Default Re: (junglerunna02)
I also barely failed emissions due to the emissions system looking for the factory 1.5L.
I'll be going down there again though running my mom's stock P28 off of her del Sol Si.
I ran around with the stock P28 on my car for about 2 days, and it ran just fine, but I could DEFINITELY tell it was running lean as hell.
But I'm currently switching the water pump/timing belt before I go back to the emissions.
Try running a stock P28 or a P06 ECU to lean your car out as if the 2.2l is running as a 1.6l.
HTH.
Old Jun 25, 2003 | 12:24 AM
Default Re: (poison)
Alright I guess I could try that, except for the fact no one I know mods hondas. Resulting in no one have those 2 types of ecu's laying around.
WOuld the map sensor have anything to do with whats wrong?
Old Jun 25, 2003 | 04:38 AM
Old Jun 25, 2003 | 04:54 AM
Krnbk2's Avatar
damn, now you got me worried since i Live in NJ too and was planning on going with an h22 swap in my ej6 as well. Hopefully you get this all figured out and can let us all know what it was
Old Jun 25, 2003 | 06:29 AM
Jonathan_ED3's Avatar
Default Re: (krnbk2)
get your EGR system fully hooked up and running.
It can FOR SURE cause you to fail hardcore. If you still don't pass, then try to lean it way out.
Old Jun 25, 2003 | 06:38 AM
Default Re: (hot_EH)
Im in the process of buying someones EGR solenioid and trying to completly hook up EGR.
Old Jun 25, 2003 | 06:50 AM
SpeedMonkeyRacing's Avatar
Problem #1: 2.2/1.6 liter emissions are different
Problem #2: Aftermarket cat sucks and those cat are prone to go bad in NO TIME
Problem #3: OBD1 instead of OBD2.
Problem #4: They don't care what exhaust you have...if you have one and they wanna be an ******* about it...you're failed!
Your NOX is way over the limit
Jeff-
Old Jun 25, 2003 | 06:55 AM
Default Re: H22 EJ6 Failed Emissions, But Why? Take a Look! (Corporal-Jeff)
Well the cat is a month old, so that cant be it. I guess I might have to find someone to help me out.
Old Jun 25, 2003 | 06:57 AM
my cat last me about 1000 miles...
then my friend told me that it was flying out of my exhaust
Jeff-
Old Jun 25, 2003 | 07:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">Im in the process of buying someones EGR solenioid and trying to completly hook up EGR. </TD></TR></TABLE>
Are you getting the electrical plugs with it? If not, it's going to be a PITA to hunt those down.... take a look in my sig
Edit: Well I forgot that I took it out pending a sale But it took me over a month to even find anybody with the plugs, much less one willing to sell them
Old Jun 25, 2003 | 07:06 AM
Im getting this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">Well the cat is a month old, so that cant be it. I guess I might have to find someone to help me out. </TD></TR></TABLE>
I got my June '04 sticker just recently
