Need Sohc ZC vacuum line HELP!!!!
hey yes like the title says i need help with the vacuum lines in my 88 crx Hf with a sohc ZC. would anybody be able to post pictures of how everything is connected on your ZC, and also let me knoe what map sensor assymbly you are using? my car still runs a little off and its flashing a code 1 "oxygen content". so please post the pics so i can get my car running legit. THANX!!
im having the same problem, i think it comes down to not having a good clean ground on your thermostat, thats what the haynes manual says. i have everything ran normal, except i just left the egr vacuum hose(#16) off, not blocked or anything. im gonna mess with it tomorrow when i get off work and clean my grounds on the thermostat, hopefully that will fix it. if you figure it out, or already have, let me know, cause i have the same setup and problems you're having
my 4 door only has the map sensor and the other chingadera going to the IM. its pretty straight forward.
Alse look under the hood it has a diagram there.
crxguy406
Aug 15, 2012 03:28 PM
crxdriver89
12
Feb 28, 2006 10:00 PM
