Machining 97' JDM ITR head
Old Jun 24, 2003 | 10:07 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Machining 97' JDM ITR head
Bought a 97 JDM ITR head, didnt think about it not coming with factory cam towers, has anyone here ever had a set of v-tec caps (b16, b18c1, b18c5) mounting surfaces shaved then the cam bores re-bored to the factory diameter to repair problem, similar to what some blocks have done on bores
From what I understand you have to have the cam towers that actually came with the head from the factory to use the head again or buy a set of cam towers off of si, gsr, or type r and have the machine work done. thanks.
Old Jun 24, 2003 | 10:49 AM
arw321's Avatar
Default Re: Machining 97' JDM ITR head (v-attack)
All cam caps are specific to the heads that they originally come with. They are machined to fit each other, so to speak.
I believe to get another set to work you need to grab another set and have everything "line bored".
HTH,
Adam
Old Jun 24, 2003 | 12:11 PM
ill phil's Avatar
Default Re: Machining 97' JDM ITR head (arw321)
Depending on how much you get another set for and the cost of machine work to line bore and if that would even work to factory specs, you could maybe find another complete ITR head minus cams for around 700-800. But you did already drop the $$ on this head
Old Jun 24, 2003 | 01:36 PM
v-attack's Avatar
hey its me and baonest's head hoss, same head
Old Jun 24, 2003 | 07:36 PM
ill phil's Avatar
Default Re: (v-attack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote">hey its me and baonest's head hoss, same head</TD></TR></TABLE>
Yeah I realize that, and I'm saying you already spent the money on it.
Muckman
Sep 11, 2011 04:58 PM
ildknyli
Oct 10, 2004 10:21 AM
v-attack
Aug 21, 2003 12:01 PM
baonest1
Jun 24, 2003 11:37 AM
v-attack
Jun 24, 2003 11:33 AM
