speed limiter? is there a way to take it outta the stock ecu?
can i remove this feature? i've "heard"(im not sure if its right) that a vafc or safc might be able to mess with it. but i have no idea about it. please help me out if u can
Guest
Posts: n/a
goto http://www.spw-usa.com and find a pivot speed meter, they are around 110 bux and will get rid of your limiter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR-V »</TD></TR><TR><TD CLASS="quote">i've "heard"(im not sure if its right) that a vafc or safc might be able to mess with it.</TD></TR></TABLE>
The Field SFC VTEC controller does advertise a speed limit removal feature, although they also mention that it does not work on "some models". The Apex-i VAFC doesn't offer the feature at all, because it does not intercept the VSS signal like the SFC does. I've never used this feature personally, but I think the chances are good that it would work on your application.
On my 99 EX it cuts off at 122mph everytime, though one time it did seem like it topped out at 115 turns out my car is just to damn slow to go any faster up the slight incline. I did a 10 hour road trip and messed around with the top speed a lot and came up with 122mph.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
The Field SFC VTEC controller does advertise a speed limit removal feature, although they also mention that it does not work on "some models". The Apex-i VAFC doesn't offer the feature at all, because it does not intercept the VSS signal like the SFC does. I've never used this feature personally, but I think the chances are good that it would work on your application.</TD></TR></TABLE>
yep..its true, the Fields SFC controller DOES disable the speed limiter when used in an 88-91 EF civic & DA integra. Not sure about OBD1 vehicles though.
