dsm 450cc injectors, obd1 vs obd2, and resistor boxes.....
Old Jun 24, 2003 | 09:02 AM
Black R's Avatar
25 Year Member
Default dsm 450cc injectors, obd1 vs obd2, and resistor boxes.....
I have an obd2.2 integra ('98+), and would like to run 450cc dsm injectors with my stock ecu (p73).
Can someone please explain what I need to do with a resistor box? Where do I wire it in, and what exactly does it do?
Also, when I switch to an obd1 ecu (hondata p28) in the next couple of weeks... will I need to reconfigure this setup somehow?
I know all of this has to do with saturated and peak/hold... but please break it down for me.
Thanks.
Old Jun 25, 2003 | 06:01 PM
Rocket's Avatar
Default Re: dsm 450cc injectors, obd1 vs obd2, and resistor boxes..... (Black R)
Still need help?
Old Jun 25, 2003 | 06:12 PM
Black R's Avatar
25 Year Member
Default Re: dsm 450cc injectors, obd1 vs obd2, and resistor boxes..... (Rocket)
Yes please!
You can see I've had 0 responses.....
Old Jun 25, 2003 | 06:18 PM
Rocket's Avatar
Contact ef-1 tech support in my sig. He should be able to help you. He has a huge amount of knowledge and is friendly.
Old Jun 25, 2003 | 06:21 PM
poison's Avatar
The reason a resistor box is needed is because the DSM 450's are low impedence injectors that send different voltages and is necessary to run a resistor box.
It's hard to explain while typing, and I have a diagram somewhere, I'll have to look for it.
But basically you take the Yel/Blk wires from the fuel injectors, cut them from the Engine harness, with enough slack from the fuel injector harness themselves.
You wire those Yel/Blk wires to the Resistor box from the fuel injectors, and wire up the 5th wire (depending on what resistor box it is) to the yel/blk wires from the engine harness.
As for the converting to OBD1, no you will not. I would just get the Hondata tuned for your set up and run an OBD2b to OBD1 jumper harness using the P28.
HTH.
Old Jun 25, 2003 | 06:28 PM
Rocket's Avatar
Default Re: dsm 450cc injectors, obd1 vs obd2, and resistor boxes..... (poison)
Good info.
Hey Brandon.
I like your sig.
Old Jun 25, 2003 | 06:31 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Good info.
Hey Brandon.
I like your sig.</TD></TR></TABLE>
I like your products.
Old Jun 25, 2003 | 06:32 PM
Rocket's Avatar
I think 99Hybrid_Hatch has some good advice on H22/H23 tensioners.
Old Jun 25, 2003 | 06:35 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">I think 99Hybrid_Hatch has some good advice on H22/H23 tensioners.</TD></TR></TABLE>
Already talked with him in the Prelude forum
https://honda-tech.com/zerothread?id=545446
Good info he gave. I need to order me one within the next couple days.
Old Aug 30, 2003 | 08:48 AM
Black R's Avatar
25 Year Member
.....do you have that diagram anywhere?
The resistor box just has a plug on it.....
BTW: which resistor box should I use (or does it matter)? Any year honda?
DSM injectors use obd2 injector clips, right?
Old Aug 30, 2003 | 08:57 AM
R6Boy69's Avatar
ive got a resistor box for you... I can give you both plugs also with some of the wiring harness... let me know
Old Aug 30, 2003 | 09:59 PM
PHiZ's Avatar
Default Re: dsm 450cc injectors, obd1 vs obd2, and resistor boxes..... (crXBoy69)
Wow, people don't know how to search, this has been covered in depth, one MILLION times :mrevil:
-PHiZ
Old Aug 31, 2003 | 03:05 PM
Black R's Avatar
25 Year Member
Default Re: dsm 450cc injectors, obd1 vs obd2, and resistor boxes..... (PHiZ)
.....thanks for not linking me:
https://honda-tech.com/zerothread?id=576796
for others, this thread has a lot of info.....
redpreluder
Oct 27, 2006 05:52 AM
e jay one
Aug 6, 2005 02:48 PM
B_1_8_hatch
May 6, 2003 04:52 PM
robbieshonda
Apr 25, 2003 07:34 AM
teg92
Dec 13, 2002 11:08 AM
