Installing a regular AEM Cold Air Intake for a 97 GSR into a hybrid gs-r hatch (EG)
Does it fit right ? or is there any other modifications needed ? Because im doing it today,
Thanks, Arbi
Thanks, Arbi
If you want to keep it from rubbing up against the unibody, you're going to need to cut it in at least one place. Secure the cut area with a rubber sleeve and some hose/aviation clamps (hardware store, $6 total). It will be worth it and it allows you to make a short-ram in the rainy season.
what exactly is the unibody and how could I make it NOT scrape like you are saying ?
i read you sig and do you just drop your clutch and go. Oh and the unibody is the frame of your car his saying that you'll have to knotch out the hole a little for the cold air to fit or cut the cai one of the two
vietfella
Apr 9, 2007 10:53 PM
civicgsr96
May 31, 2002 03:48 AM
