A few emissions questions
Old Jun 23, 2003 | 08:36 PM
bluedelsol's Avatar
Default A few emissions questions
I took my emissions test today and failed on HC and CO%.
My HC's were 190@15mph (limit is 124) and 174@25mph (limit is 120)
My CO% was .72@15mph (limit is .70) and .81@25mph (limit is .67)
Passed NO fine.
Is this close to passing or is it way off?
and are there any things i can do to make it pass? and tricks like boosting the octane of the gas alot?
Old Jun 23, 2003 | 08:44 PM
poison's Avatar
Default Re: A few emissions questions (bluedelsol)
What is your set up? What ECU you running?
Any codes? O2 sensor working properly?
Sounds like you are on the verge of passing, just probably running a little richer than the norm in order to pass emissions.
That is pretty close to passing, you just barely missed it.
If you have any codes, fix them, the ECU is most likely running in a mode that could cause you to run a little richer than in closed loop mode. Make sure the O2 sensor is good, as well as full working Catylatic Converter.
If you are also running a chipped ECU, try borrowing a stock ECU or another ECU that will lean the motor out a little more to reduce emissions.
It will not harm your motor, just don't abuse the hell out of it. Being at 15 MPH and 25 MPH and such won't do anything.
Old Jun 23, 2003 | 08:49 PM
bluedelsol's Avatar
Default Re: A few emissions questions (poison)
it's a d15b7 with a d16y8 head (and every bolt on including full msd ignition), no codes, stock ecu, i'm prity shure the cat and o2 sensor or good because my A/F ration gauge is workin good. but when i step on the gas hard it goes to fuel rich, should i lower my fuel pressure and retard my timing a little? and would boosting the octane alot help since higher octane fuel burns hotter?
Old Jun 23, 2003 | 08:54 PM
poison's Avatar
Retard the timing a little, get yourself some octane booster, and set the fuel pressure to about 40 PSI at WOT.
Old Jun 23, 2003 | 08:57 PM
bluedelsol's Avatar
ok, cool, thanks for the help
Old Jun 23, 2003 | 09:06 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedelsol &raquo;</TD></TR><TR><TD CLASS="quote">ok, cool, thanks for the help</TD></TR></TABLE>
np
Old Jun 24, 2003 | 01:52 AM
irev210's Avatar
how will retarding the timing do any good? That would make it run cooler, which would reduce NOx, but wouldnt help him pass emissions. If your fine on the NOx, just turn down your FPR so you run leaner. which would also increase your NOx a little, but your fine there anyway. How old is your cat is the most important question. If you have a new cat, then just turning down the Fuel pressure will be fine. If you have a cat that is older then 6 months old, you will see some really good improvments with a replacement.
Also, new plugs, fresh oil, a properly working ignition system will always help
Old Jun 24, 2003 | 04:06 PM
bluedelsol's Avatar
Default Re: A few emissions questions (irev210)
aright well i took my re-test today and faild again, it got worse.
HC=201@15mph (limit 124) 229@25mph (limit 120)
CO=75@15mph (limit 70) 68@25mph (limit 67, this acually got better)
NO=157@15mph (limit 989) 333@25mph (limit 894) this got alot better but was fine before
i retarded my timing, re-set my ecu, added alot of octane booster and loweres the fuel pressure, WTF? why did it get worse?
Old Jun 24, 2003 | 04:20 PM
poison's Avatar
How old is your cat?
Old Jun 24, 2003 | 04:28 PM
bluedelsol's Avatar
i dont know, its been on there since i bought my car last year
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedelsol &raquo;</TD></TR><TR><TD CLASS="quote">aright well i took my re-test today and faild again, it got worse.
i retarded my timing, re-set my ecu, added alot of octane booster and loweres the fuel pressure, WTF? why did it get worse?</TD></TR></TABLE>
The reason why your nox got alot better is because u retarded your timing. But I think that hurt your HC's.
What is ur fuel pressure set at, and how old is your cat
Old Jun 24, 2003 | 04:30 PM
irev210's Avatar
a new cat and ull pass
bluedelsol's Avatar
for some reason my FPR gauge isnt working so i dont know what is is set at, my cat has been on there since i bought my car last year, it's a 94 del sol so i dont know when it was replaced last.
Old Jun 24, 2003 | 04:32 PM
poison's Avatar
I'll say get a new cat and you should no problems passing.
Old Jun 24, 2003 | 04:36 PM
bluedelsol's Avatar
do i need a stock cat to pass or will a high flow one work?
Old Jun 24, 2003 | 04:38 PM
irev210's Avatar
a high flow will work fine
just make sure its hot on the dyno
Old Jun 24, 2003 | 04:40 PM
bluedelsol's Avatar
ok, thanks for the help, i'll buy one tonight, i'v been meaning to buy one anyways
Old Jun 24, 2003 | 04:44 PM
irev210's Avatar
ull pass with a new cat, just watch
it'll be night and day difference, ur close anyway
just make sure u do some fun freeway driving and get it nice and hot
Old Jul 24, 2003 | 06:37 PM
bluedelsol's Avatar
aright, i got a new cat and it still failed. but just on the HC ppm's.
15mph:
limit-124 reading-273
25mph:
limit-120 reading-179
new O2 sensor?
Old Jul 24, 2003 | 11:39 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedelsol &raquo;</TD></TR><TR><TD CLASS="quote">I took my emissions test today and failed on HC and CO%.
Passed NO fine.
and are there any things i can do to make it pass? and tricks like boosting the octane of the gas alot?</TD></TR></TABLE>
So your getting 190 parts per million of HC and 67 percent of CO - what is your co2 reading -
Well HC reading is an indicator of a misfire and CO reading is an indicator of Rich mixture - since your CO is lower than Your HC you may have lean misfire - However, poss you o2 reading that way I see if it is lean mis. But anyway, if it is a lean mis check your fuel filter - remove it pour out the fuel into a clean bowl to see if is dirty (clogged)?
Old Jul 25, 2003 | 03:38 AM
hondamanwill's Avatar
needs cat!!!!
Old Jul 25, 2003 | 02:38 PM
bluedelsol's Avatar
Default Re: (hondamanwill)
i already replaced my cat, read my last post.
Old Jul 25, 2003 | 02:56 PM
sorry i should read more!
Old Jul 25, 2003 | 03:00 PM
bluedelsol's Avatar
obd1, 94 del sol
Old Jul 25, 2003 | 03:05 PM
check timing, coolant temp sensor may cause it. running to much fuel and not enough air. o2 sensor may cause it if it's running lazy. but do timing first.
