Choosing between Toda C and Jun 3
Guest
Posts: n/a
What are your plans????
What is your compression???
JUN3s idle like stock no problem, Toda's can be made to idle like stock, but a bit harder.
Toda provides much better low/mid range power, whereas JUN surpasses all at top end.
With our fully built motor we had (14.1 CR) JUN3s made 11 whp more than the todaCs,
Every setup is different.
first of all, i dont mean to be rude, but if you search, it will help out quite a bit.
TodaC's and JUN3s are different. LIke said above JUN makes much more power up top, then those the Toda Cams.
With either cam you will need to raise your compression quite a bit to get total use of the cams.
What do you plan on doing w/ your car, Drag racing? AutoX?? etc... This is too much of a general question. But all the Toda lovers on this board will go for toda. my vote is for the JUNs, been using them for years, not on complaint.
KK u're currently running around 12.3-12.5:1 compression am I correct? Think he got his internal done. He probably just need some bigger cams for more power.
just a suggestion, if youre looking into the JUN 3's, you should also look into the skunk2 stage 2's. they have pretty much the same specs as the JUN 3's, except there is a slight difference in the duration, and theyre about $300 less than the JUN's.
ive talked to people who got the JUN 3's before the skunk2's were released and they all said if they could do it over again, they would have gone with the skunk2 stage 2's. just something to think about
SPOONfdEK
Aug 26, 2004 07:30 PM
TEGPOWER44
Jul 9, 2002 11:08 AM
TEGPOWER44
Jul 7, 2002 12:47 PM
