D15b(v-tech) into my 89 crx hf?
Old Jun 23, 2003 | 08:09 PM
jlong17crx's Avatar
Default D15b(v-tech) into my 89 crx hf?
I have a 1.5 in my 89' hf, I also have the D15b(v-tech) engine here. How hard is it to put in?can I use alot of the same parts(like the axels,ECU,...) or is it hard? please e-mail me if you know what you are doing!
Thanks
Old Jun 23, 2003 | 08:17 PM
Malgerus's Avatar
Default Re: D15b(v-tech) into my 89 crx hf? (jlong17crx)
First of all, you have a VTEC engine, not a vtech
Anyways, yes, you can use your stock tranny and axles, though I'd reccomend upgrading to Si. Your engine mounts will work too.
Old Jun 23, 2003 | 08:19 PM
poison's Avatar
Just FYI, it's VTEC.
As for swapping in the D15B, it's pretty much just swap in. You will need to obtain and/or convert the car to OBD1, however. I would recommend you adapt the factory OBD0 and add the VTEC wires to the ECU using an OBD0->OBD1 jumper harness and using a P28.
Old Jun 24, 2003 | 03:06 AM
irev210's Avatar
Default Re: D15b(v-tech) into my 89 crx hf? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Just FYI, it's VTEC.
As for swapping in the D15B, it's pretty much just swap in. You will need to obtain and/or convert the car to OBD1, however. I would recommend you adapt the factory OBD0 and add the VTEC wires to the ECU using an OBD0-&gt;OBD1 jumper harness and using a P28.
he could stay obd0 and get endyne aswell
or some vtec controller
obd1 is the way to go though
saveacivic
May 4, 2011 12:10 PM
crazykamper
Oct 16, 2006 06:26 PM
deerek101
Feb 15, 2006 11:03 PM
MadModder
Oct 11, 2005 06:02 AM
chrisblack
Nov 20, 2004 09:17 AM
