fuel pressure regulator....
Old Jun 23, 2003 | 06:51 PM
guywitahatch316's Avatar
Default fuel pressure regulator....
I have a 91 ef hatch of course with a b16a swap and i was wondering what is the best fuel pressure regulator to buy.. or should i buy one.....what should i do?????
Old Jun 23, 2003 | 07:18 PM
91civicDXdude's Avatar
just so you know, they are all pretty much the same, i mean if they can adjust the fuel pressure, its doing its job.
something else you should know however, is the AEM (more expensive) ones are a complete unit, however the B&M (helluva lot cheaper) is the top piece only, you have to saw your stock regulator in half and attach the B&M top piece to the bottom of your stock regulator. I have the B&M, had it for about 6 months now with no problems whatsoever, just make sure you get a gauge with it.
Old Jun 23, 2003 | 10:30 PM
Default Re: (91civicDXdude)
how much did the b&m cost
Old Jun 23, 2003 | 10:52 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (guywitahatch316)
Mine cost me 40 plus 30 for the guage.... I have not got to use it yet since I couldnt get it to stop spewing fuel from the rail.... Supposedly they are good units.
Blaze
Old Jun 24, 2003 | 05:16 AM
zCivic's Avatar
Default Re: (Blaze45)
I've got the B&M its a good one. Only down fall is with a high pressure pump you cann't get below 40psi with no vacumn even though they say will go down to 25 but other then that its a good one for the price for sure. Def get a pressure gauge though no matter what you go with
h22 ac
Aug 13, 2006 01:48 PM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
schtozo
Dec 8, 2002 01:07 PM
808eg6
May 8, 2002 10:37 PM
