H22 problem maybe msd related
Old Jun 23, 2003 | 06:36 PM
Akkord29's Avatar
Default H22 problem maybe msd related
well i have had my msd on for about 8 months and my stock wires for about 1 year. recently the car (h22 accord) started stutter alot upon accleration and when i just ease off the acclerator and keep it level its fine, when i go back and add more gas the stutter begins big time and popping noise from the exhaust. I changed the spark plugs last tonite to no prevail. Planning on picking up some msd wires tomm. Anyone have any answer. The stutter is alot.
Old Jun 23, 2003 | 06:54 PM
Accord94DX's Avatar
Default Re: H22 problem maybe msd related (Akkord29)
sounds like a misfire.
Old Jun 23, 2003 | 09:35 PM
KTeller8's Avatar
Default Re: H22 problem maybe msd related (Accord94DX)
maybe you running rich?
Old Jun 23, 2003 | 09:44 PM
AznPimpS's Avatar
i have same problem
is your fuel system , mixture of air/fuel is not correct
as i am tryin to tune mine now
Old Jun 24, 2003 | 06:50 AM
Jason kiDD's Avatar
You need a full tune up. Plugs, distro cap and rotor, maybe wires..
Old Jun 24, 2003 | 07:10 AM
carolinaACCORD's Avatar
Default Re: H22 problem maybe msd related (Jason kiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason kiDD &raquo;</TD></TR><TR><TD CLASS="quote">You need a full tune up. Plugs, distro cap and rotor, maybe wires..</TD></TR></TABLE>
correct. if anything the MSD helped you, not hurt it.
Old Jun 24, 2003 | 07:18 AM
Akkord29's Avatar
Default Re: H22 problem maybe msd related (carolinaACCORD)
aite guys ive changed the plugs to no prevail, im going to pick up a set of wires in an hour and if that doesnt work, i will stop by honda and get my cap and rotor. I will let you know how it turns out later tonite. thanks for all the input
Old Jun 24, 2003 | 07:25 AM
f22a6hitz's Avatar
well, is ur car an everyday driver?
i heard some good and bad things about msd modules.
ive heard they work fine and sometimes they dont. i was plannin to get one but after doin research and seeing reviews on it i changed my mind, to many people were saying that it started to act up after a while, then once they uninstalled it, there car was fine.
my father had to send his to msd for them to fix it because his was acting up.
Old Jun 24, 2003 | 07:26 AM
Jason kiDD's Avatar
change cap and rotor first. Plug wires last..
Old Jun 24, 2003 | 08:13 AM
Default Re: (f22a6hitz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22a6hitz &raquo;</TD></TR><TR><TD CLASS="quote">well, is ur car an everyday driver?
my father had to send his to msd for them to fix it because his was acting up.</TD></TR></TABLE>
I've had mine on for about a year, no problems. The #1 reason they mess up is because people mount them wrong and they vibrate to death. People don't use the supplied bushings.
Old Jun 24, 2003 | 10:23 AM
2point6's Avatar
Default Re: (carolinaACCORD)
When is the last time the o2 sensor was changed?
Old Jun 24, 2003 | 04:21 PM
Akkord29's Avatar
hey it was the cap and rotor. car all better now.
But should i still get some upgraded wires rather than the stock ones?
Old Jun 25, 2003 | 05:39 AM
Jason kiDD's Avatar
I found that there is minimal gains from changing to aftermarket wires. And since you have the MSD there probably isnt a real need. You can change to NGK 8mm series if you want and you should be just as good. MSD and magnacore makes good wires as well.. Its all up to you though..
Acuronda_SloTeg
Nov 9, 2007 11:40 PM
SpoolnG2
Jun 26, 2004 03:55 AM
Opie
Sep 29, 2003 08:43 AM
StageIIIhb98
Dec 17, 2002 05:58 PM
b18apwr
Oct 9, 2002 12:36 PM
