a 1.5 inch drop
Old Jul 24, 2001 | 07:48 PM
StinkyTofu's Avatar
Default a 1.5 inch drop
I'm planning on getting ground controls, i wannna do a 1.5 inch drop, is that low enough that i'll need to get a camber kit? If not i'd prefer not to get one.
Old Jul 24, 2001 | 09:59 PM
George H's Avatar
Default Re: a 1.5 inch drop (IntegraGSR)
Well with a 1.5" drop you could also go with a spring/shock combo (ie. Eibach Prokit+a shock of your choice). Unless you are looking for the adjustability that the coilover offers. A rule of thumb is that camber remains stock at stock ride height. So, yes your camber will change but with just a 1.5" drop you will most likely not need a camber kit. Bear in mind that every car is different, but the majority of people will not need a camber kit for that minor drop. The drop will give you a little negative camber which is good and not negative enough to generate premature wear on the inner edges of the tire.
Old Jul 25, 2001 | 12:07 AM
BishopB18C1's Avatar
Default Re: a 1.5 inch drop (KANJI)
check out the H&R OE's and the Nuespeed soft sports.
civicej8ftw
Feb 1, 2009 05:27 PM
AgentJam
Sep 11, 2003 06:09 AM
Wazup
Jan 24, 2003 12:47 PM
crashtest2600
Jan 18, 2003 01:15 AM
ayacht
Oct 11, 2002 07:09 AM
