can a LS flywheel be used in a GSR
I have an extra ls fidanza flywheel laying around, and i was wondering if it would work on a gsr motor, with a gsr trans? I was thinking it wont work with a gsr clutch housing, i would have to use a ls housing with a gsr disk.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwn-shift »</TD></TR><TR><TD CLASS="quote">I have an extra ls fidanza flywheel laying around, and i was wondering if it would work on a gsr motor, with a gsr trans? I was thinking it wont work with a gsr clutch housing, i would have to use a ls housing with a gsr disk.
thanks</TD></TR></TABLE>
Yes it can be reused on a GSR engine.
What year of tranny/flywheels are you regarding to ?
I ask this because if the Fidanza LS flywheel was made for a hydro LS tranny and you want to apply it to a GSR engine w/hydro GSR transmission....by all means it will work....and it doesn't matter which pressure plate+disc you use on it either. All Hydro b-series transmissions are compatible with each other. Same goes for cable b-series trannies too.
EKB18BPR3
22
May 17, 2004 07:24 PM
