rear sway bar
What are the part numbers that are needed to put a rear sway bar on a CX? All i can find from aftermarket sites are kits for cars that are factory equiped with them. And the Honda and Acura sites i have are kind of misleading, since Carland doesnt have a photo of the rear im not sure what they call the parts.
if you want to do this right the first time, You may want to go with an Integra type r Usdm Rear sway! 22mm I believe and all you will need are lower control arms from a 94-00 gsr or ls, or 92-95 ex/si 's should have the control arms with hole for the sway bar endlinks. Then You can order your rear sway and Suspension reinforcement kit from Beaks products or Bsq kit. ( a must for mounting Itr rear bar on eg chassis or dc2 gsr/ls.
p-p-porkchop
Suspension & Brakes
27
May 20, 2006 10:31 AM
Weston
Jun 3, 2002 04:55 PM
