tire size
Old Jun 23, 2003 | 09:44 AM
JetSI's Avatar
Default tire size
What is the largest size you can put on stock rims with no rubbing? The car is 1992 Prelude SI.
Modified by JetSI at 7:26 PM 6/23/2003
Old Jun 23, 2003 | 02:15 PM
WuWarrior's Avatar
Default Re: tire size (JetSI)
I use 225/50/15 for my competition tires. It barely rubs on the inside when the wheel is turned all the way.
This is with Eibach pro-kit springs/Koni yellow's. I am not using stock rims so the offset might be different.
If your car is not lowered, 225/50/15 should work fine. 225/55/15 would be closer to the correct diameter but it's much harder to find tires in that size.
Decatur Racer
Jan 1, 2009 06:43 PM
twentyhurtz
Nov 25, 2008 05:02 AM
swatteamtimmah
Jan 22, 2006 06:19 AM
onecamsivik
Mar 2, 2005 11:13 AM
E-spec Tuner
Jun 30, 2004 06:26 AM
