D15 into a 90 SI
Old Jun 23, 2003 | 07:51 AM
boosh's Avatar
Default D15 into a 90 SI
alright, im going to try and be as specific as possible. i'm buying a 90 crx SI with a transmission and axles and i just purchased a d15b7 to put in it. the motor is obd1, so will i need to get an obd1 civic dx wiring harness or will any non vtec obd1 harness work? and also, will any non-vtec ecu run the motor?
Old Jun 23, 2003 | 08:19 AM
ThatRicerDaniel's Avatar
Default Re: D15 into a 90 SI (boosh)
just get a 91 dizzy and use a 91 harness. and yes almost all the non vtec ecu's will work
Old Jun 23, 2003 | 09:31 AM
4drEF's Avatar
Keyboard Humorist
DX and Si engine harnesses are different. The firewall plug pinouts are different.
Use the engine harness that was made for your car and convert it for the swap engine as necessary.
Old Jun 23, 2003 | 11:42 AM
boosh's Avatar
whats different from obd1 to obd0 i know theres a knock sensor, an o2 sensor and something else... but the motor is from a 95 dx and im just wondering which ecus and wiring harnesses would work?
Old Jun 23, 2003 | 07:36 PM
boosh's Avatar
bump
Old Jun 23, 2003 | 08:25 PM
I8ayellowcrayon's Avatar
obd1? obd0? I don't know jack crap about what either of those mean, just so you know that. I'm running a D15B7 in my 89 DX. It was in there when I bought it, but I know whats going on with it.
I'm using the 89 CRX Si ECU (hatch Si will work too)
88-91 Si distributor
I think you'll be better off with the 95 harness, just because it goes with that engine, and all of the sensors will match up (i don't know if the Si harness uses the same sensors).
If you had any specific questions about something that I can point out, hit me up. But I don't know about the obd1 and 0's. So if someone could explain that to me also... I think the 1's are with the MPFI, and the 0's are for the first fuel injected models. But I may be wrong. It just seems to fit like that.
Old Jun 24, 2003 | 07:45 AM
boosh's Avatar
Default Re: D15 into a 90 SI (4drEF)
what will have to be converted from the obd0 harness to accomidate for the obd1 engine that has to go in it?
VegasEFHB
10
Oct 15, 2014 12:22 PM
stevieturbos
Nov 8, 2009 07:35 PM
bobbyisking
Jan 4, 2009 10:35 PM
lazyboy
Oct 8, 2005 06:49 AM
usdm_ED7
11
Jun 20, 2003 08:01 AM
