porblem with my car>>>>>>>>>>
Old Jun 23, 2003 | 07:48 AM
Si_Power's Avatar
Default porblem with my car>>>>>>>>>>
ok so one day im driving and my gauge cluster and dash lights went out, so i looked at the fuse and it was bad so i put another in and it blew out right away so i try a couple more and i keep getting the same ****. if anyone knows anything to help that would be awsome.
Old Jun 23, 2003 | 07:51 AM
ProEater's Avatar
Default Re: porblem with my car>>>>>>>>>> (Si_Power)
you may need to put a stronger fuse in. what fuse is blowing?
Old Jun 23, 2003 | 07:55 AM
PhucNguyen57's Avatar
Default Re: porblem with my car>>>>>>>>>> (ProEater)
DO NOT PUT A STRONGER FUSE IN unless the car calls for it. YOu could burn up your harness. I would jsut go through makeing sure nothign is grounding out, and check to make sure all the fuses are the right amp.
Old Jun 23, 2003 | 07:58 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProEater &raquo;</TD></TR><TR><TD CLASS="quote">you may need to put a stronger fuse in. what fuse is blowing?</TD></TR></TABLE>
umm........DO NOT PUT A BIGGER FUSE IN!!!!!!!!!!!!!!!!!!!!!!!!!! sounds like you have an electical problem.....a wire shorted out somewhere.
Old Jun 23, 2003 | 07:59 AM
ProEater's Avatar
Default Re: porblem with my car>>>>>>>>>> (PhucNguyen57)
good point. thats why i was asking what fuse it was.
Old Jun 23, 2003 | 08:02 AM
civickidd99's Avatar
definately do not put in a larger one, fuses are supposed to be the weakest link in your electrical system, so if you put a larger one in it won't blow and cause other things to burn up
Old Jun 23, 2003 | 08:12 AM
superrally's Avatar
do you have a monster stereo system?
Hanmin
May 16, 2008 02:17 AM
hondaEg_808
10
Apr 19, 2008 12:40 PM
BLUE EH3
Mar 15, 2007 12:24 PM
GreenD16Y8
Aug 8, 2005 03:59 PM
GReddy212
Apr 12, 2005 10:56 AM
