lsd question for those who have changed their stock lsd
hey guys...come to find out my differential broke in my b16 tranny a few days ago so i need to replace it. i was just wondering for those who have changed from the stock type r lsd to a different brand, was it worth the money for the difference it made? i am going back and forth between the type r and a quafe yet im on a budget (college) thanks for your help in advance.
I have an ITR LSD in my GSR transmission and I haven't had a problem yet. Only problem you are going to run into is you are going to need the ring gear, pinion gear, and associated parts so that you can run that diff.
I think both options will cost you roughly the same amount...
personally i would put a spoon, kaaz, or ats LSD in a tranny before an itr if i had the money for one.....spoon would be my first choice since it comes with new bearings...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyg »</TD></TR><TR><TD CLASS="quote">
You should be able to find a used ITR LSD for 400-450$
I doubt you'll be able to find a used Quaife, and new ones are about $800.</TD></TR></TABLE>
Correct. However he is putting it into a b16 transmission, which requires a ring gear, counter shaft/pinion gear (IIRC), plus some new bearings. The ring gear alone is just over $200, which is how I figured w/ the cost of the other parts he would be up around that magical $800 mark.
thanks for the heads up...i was thinking it would be cheaper but thats why i ask. what are all the parts i will need to put it in so that i have all and know all that i need to purchase for the type r? then also what all do i need to install a quafe?
type R lsd into B16a hydro tranny
parts needed (easiest way)
ITR LSD
ITR LSD carrier barrings (closed)
JDM Final drive setup
this can be had for about 850ish.....that is what i would do with b16 tranny....plus you get a good final drive!
ITR LSD
thanks i think that is what im going to do...price sounds good to me along with the benefits. now does anyone have any tips into installing the final drive stuff
